Illuiminated Rear Heated Window Switch
kam-325i
I want to do the mod as in the tech articles, where do i get the "Modified" switch from ?
buster
Ask Ian haynes nicely and he may do you one,he's the man for these.
kam-325i
aahh. so you have to mod the switch aswell........buster wrote:Ask Ian haynes nicely and he may do you one,he's the man for these.
johno
yes mate ou need demister switch and a hazard switch to mod
kam-325i
Take the bits out of the donor hazard and put into the demister ?johno wrote:yes mate ou need demister switch and a hazard switch to mod
ian332isport
Yeah, that's basically what needs doing. I also change the reisistor value to give the correct brightness.kam-325i wrote:Take the bits out of the donor hazard and put into the demister ?johno wrote:yes mate ou need demister switch and a hazard switch to mod
Aparently you can just swap the switch cover from a heated rear window switch into a hazard switch and it works. Never tried it like this though.
Ian.
kam-325i
Right, Ive got the two switchs in front of me, both in peices, which bits from the hazard do i put into the rear heater ?
stevetigger
http://www.e30zone.co.uk/modules.php?na ... witch1.htmkam-325i wrote:Right, Ive got the two switchs in front of me, both in peices, which bits from the hazard do i put into the rear heater ?
That might help!!
kam-325i
Thats not what i need, The Actual rear heated Screen Switch internals need bits adding to it from the inside of the hazard switch. But i dont know which bits.....
smithy318i
yes you can do thatAparently you can just swap the switch cover from a heated rear window switch into a hazard switch and it works. Never tried it like this though.
kam-325i
WooHoo, Right then, just got to rebiuld the damm switches now !!!smithy318i wrote:yes you can do thatAparently you can just swap the switch cover from a heated rear window switch into a hazard switch and it works. Never tried it like this though.
oze30
Then what are the rest of the wires out the back of the plug (window) for? If I remember, the hazard has less wires. Eitehr way.. I'm going to do this mod right now! ;)
Cheers guys!
Cheers guys!
kam-325i
The Hazard Switch has 8 Connetors on the back, the heated screen switch has 4.oze30 wrote:Then what are the rest of the wires out the back of the plug (window) for? If I remember, the hazard has less wires. Eitehr way.. I'm going to do this mod right now! ;)
Cheers guys!
smithy318i
yes but the 4 terminals on the heater switch is the same layout as the 4 on the hazard switch.kam-325i wrote:The Hazard Switch has 8 Connetors on the back, the heated screen switch has 4.oze30 wrote:Then what are the rest of the wires out the back of the plug (window) for? If I remember, the hazard has less wires. Eitehr way.. I'm going to do this mod right now! ;)
Cheers guys!
The others just are not used
FESI
So if the swap has made is the extra wire needed from the tech article or it will work without it
oze30
Hmm.. slight problem. My heated switch plug has 3 wires/pins.. where did my 4th one go???
kam-325i
Yes, as this is the "Dimmed" supply for the bulb.FESI wrote:So if the swap has made is the extra wire needed from the tech article or it will work without it
johnono
so the extra wiring is needed, u cant just swap the cover of a demister on a hazard switch and violá.
or not..
or not..
stevetigger
Good idea!johnono wrote:so the extra wiring is needed, u cant just swap the cover of a demister on a hazard switch and violá.
or not..
johnono
what is? i was askin a questionstevetigger wrote:Good idea!johnono wrote:so the extra wiring is needed, u cant just swap the cover of a demister on a hazard switch and violá.
or not..
Demlotcrew
No you cant.
Andrew
Andrew
johnono
the covers arenԚ´t actually the same or the componetry inside is different?
kam-325i
Right, here goes.johnono wrote:the covers arenԚ´t actually the same or the componetry inside is different?
Switch covers are swappable
The extra wire is needed to supply the voltage to the switch for the dimmed light.
johnono
good man for checkin that out ;)
stevetigger
You will have to come round my house Keith and show me how its done!kam-325i wrote:Right, here goes.johnono wrote:the covers arenԚ´t actually the same or the componetry inside is different?
What parts do I need to get?
kam-325i
Atleast a hazard switch to butcher, but a spare heated screen one aswell, just in case, also a spare spade connector for the heated screen.
stevetigger
You bring the spade, I will get hold of the switch's......I can see a trip to furbers! Tomorrowkam-325i wrote:Atleast a hazard switch to butcher, but a spare heated screen one aswell, just in case, also a spare spade connector for the heated screen.
Jordan
Someone please explain this modification to me?
My defroster switch already lights up, and dims with the dash lights.
So does the one in my girlfriends 89 325i...
stevetigger
Well here, the rear de-mister switch does not light up!Jordan wrote:Someone please explain this modification to me?
kam-325i
As standard, the rear heated screen switch is not illumminated when you switch on the lights, only when the switch is in the "On" position.Jordan wrote:Someone please explain this modification to me?
Not sure if this happens on US models.
kam-325i
It would have to be a weekend......stevetigger wrote:You will have to come round my house Keith and show me how its done!
stevetigger
Anytime mate, The cars in bed anyways.....So I need two switches?kam-325i wrote:It would have to be a weekend......stevetigger wrote:You will have to come round my house Keith and show me how its done!
kam-325i
Just a spare really, just in case, sods law and all that !
stevetigger
ok, Ill get a switch and then we can do this little job on my car!
I take it you mean a spare hazard switch?
kam-325i
Nah, a spare rear screen switch.
Youll need atleast one hazard switch to butcher, and a spare rear screen in case of.......something !!
