Hi guys how do you remove glass lenses from lights someone told me you can just pop them in the oven and that will heat the sealant up enough to pull the lense off is this true and how long would you need to put them in for ?
How do you remove glass lenses from lights
Very carefully!
I used to use a heat gun as its quicker
bigbird76
Hello
Have a read of this
http://www.r3vlimited.com/board/showthread.php?t=94540
Also you can run a thin blade around to cut the sealant to help things along but as Dan says you have to be carefull as the glass can easily split.
Leigh
Have a read of this
Leigh
it's tricky to say the least even touch and go for a pro .
+ a yard full of scrap turds
steve_k
Are you going to smoke the lenses? Or fit cross hairs?
if all you want to do is smoke them then why not simply use lamin-x tinting film? Saves all the hassle of trying to get the glass out without breaking/damaging it.
Ajsingh
Or you could buy my headlights ;) lolsteve_k wrote:Are you going to smoke the lenses? Or fit cross hairs?
E30 Crazy!
mani
Yeah think i might just lamin-x em and Aj your lights are out of my budget sorry man .
b12rlw
Stick them in the oven. That'll soften the adhesive.
