Hi I was looking at painting my outer sills to make them look better, where they have the black anti stonechip stuff or whatever it is. What do I use to paint over them hammerite? Or something else?
thanks
best stuff to paint outer sills with? Hi
matt86
Andros
Are ur sills just mat black or same colour as your car?
matt86
the sills are black at tjhe moment, whats the best stuff to make them look good with and rust proof them?
3M Stonechip paint or the equivalent is what the professionals would use.
matt86
thank-you, where do I get this from somewhere like halfords?Speedtouch wrote:3M Stonechip paint or the equivalent is what the professionals would use.
The_Diddler
- Love it up the more door !
This!!Speedtouch wrote:3M Stonechip paint or the equivalent is what the professionals would use.
Plus if it were me, i'd sort out any rust issues if present, prep the area and use stonechip as suggested for that factory look finish. i have found its best applied using the proper spray applicator and a decent air compresser, you wont be disapointed with the finish if done with care.
matt86
ok thanks
You can buy the 3M stuff in aerosols if you want to do it yourself and don't have spray equipment.
Hammerite also do a version:
http://www.tools-paint.com/product/Hamm ... _6_5092832
And there is Body Schutz:
http://www.consumablesexpress.co.uk/aer ... ultz-500ml
polsta
The a body shop won't charge much for just the black sills done properly , 80 maybe, for what it would cost to buy materials and the time and aggro you'd be better off paying a pro
Don't even consider ever using this sh*te on an E30! Nothing says bodged up, bridge dodging old banger better than a coating of this stuff.Speedtouch wrote: And there is Body Schutz:
Jozi
BMW do a stone chip as well in tins, it sprays on very light though. 2x 500ml tins will prob do a cill, you might get away with 3 tins.
jimmyspeed
the 3m stonechip is 08158 you can get it from here - http://www.metalflake.co.uk/products_li ... STONECHIPS also you can get the good underseal too 3m08537
darkchild
Sounds ideal for most E30s then!Brianmoooore wrote:Nothing says bodged up, bridge dodging old banger better than a coating of this stuff.
