big brake kit
Lurch320i
Thu Nov 29, 2012 10:59 pm
Ok cool.ill mock up the caliper and disc first.see how much i need and what size it'll be.then i can go from there.ill make it from wood or something first
just seen some on ebay.inch thick plates 200mm by 84mm for a couple of quid.bargain :-)
maggspower
Turbo Farmer Tractor Driver
Thu Nov 29, 2012 11:10 pm
Lurch320i wrote:Ok cool.ill mock up the caliper and disc first.see how much i need and what size it'll be.then i can go from there.ill make it from wood or something first
MDF is good for mock ups as it works easily.
You wont need it an inch thick. 15mm would be more than enough I would have thought.
Lurch320i
Thu Nov 29, 2012 11:19 pm
Ok cool thanks for the advice.i won't know how thick until i get the caliper mounted with the disc in place.ill keep you all posted.
Should i tap the aluminium where it bolts to the caliper or put a nut and bolt through?
maggspower
Thu Nov 29, 2012 11:32 pm
Lurch320i wrote:Ok cool thanks for the advice.i won't know how thick until i get the caliper mounted with the disc in place.ill keep you all posted.
The right way to do it would be, drill it then use a helicoil to thread it. You can tap aluminium, but the threaded insert is much stronger. You have to assume the calipers will be off and on to change pads. No matter how careful you are, aluminium threads just go bad sometimes.
Lurch320i
Fri Nov 30, 2012 6:40 am
Suppose so.even though you can change the pads without removing the caliper it will still be safer and stronger?
BadDave
Fri Nov 30, 2012 2:38 pm
maggspower wrote:
BadDave wrote:IIRC R33/R34 skyline calipers are pretty similar to E38 Brembo's and use the same pad.
IF the calipers are Brembo's and I think they are,then you'll have problems fitting anything less than a 302mm disk with those calipers.
I know coz I tried it quite a few years ago with 302x28mm disks and they sqeezed under a 16" rim with a high offset.It took a while till I found a thick enough1pc disk that had the correct offset,but I did manage to find a suitable one after several hours checking disk specs in the "bible" (Mintex book)
Standard master cylinder works fine with the 4 pots and E30 M3 one works fine with large pistoned 6 pots.
There's no need to change the rear unless it's a serious track car.
HTH
Dave, what discs did you use? Audi 312mm turned down? Voyager? I have some e38 calipers staring at me at the workshop :D
They do look rather large, so I need to get the tape measure out. But a head start would be nice. Cheers.
Maggs
Check for a PM with some details and a couple of pics to help you out.
BadDave
Fri Nov 30, 2012 2:44 pm
Minimum of 12mm if using steel and 15mm if using aluminium otherwise it could flex.
I use 18mm minimum with the 6 pots
Mdf is good enough to use for making the buck(template)
Pretty sure I still have the original one i used for the 4 pots somewhere. I may still have a drawing (with dimensions)or scan of it somewhere as well.
BadDave
Fri Nov 30, 2012 2:46 pm
maggspower wrote:
Jimbob wrote:What pads are people running on their E38 Brembo's?
Lurch I read somewhere the Honda S2000 discs have been used with the R32 calipers.
I would be starting with standard ones, remember if you start using performance pads you are going to have issues getting heat in to them to get them up to optimum operating temp. They are designed to stop a much heavier more powerful car.
I used off the shelf Veco ones for about £22ish from the local motor factors. Worked fine for hooning around up here
maggspower
Fri Nov 30, 2012 3:29 pm
HTH
Maggs
Mr Dave, you are a gentleman :D
I may pm you back now.
keri-WMS
Tue Dec 04, 2012 5:35 pm
We spent a lot of time (and a horrible amount of cash) going down dead ends trying to get the best disc to use on our WMS kits, and nothing that's a straight fit is worth using! A couple of points though:
- We use 6082-T6 for our brackets.
- Threaded inserts are a good idea, we go one better than helicoils by using a thicker stainless steel "solid" insert...not a "spring" style like the helicoil.
- The bore is indeed 66mm on the disc (not the wheel)
Lurch320i
Tue Dec 04, 2012 7:33 pm
Hi keri.what discs do you use then?are they custom?and do you make any that are 30mm thick to suit my caliper?
keri-WMS
Tue Dec 04, 2012 7:57 pm
Hi - we use the well known G60 280x22 disc....and our "other one", the 298.5mm jobbie. Trade secret though I'm afraid and not a standard disc (but I don't think it'll work with your calipers anyway).
Lurch320i
Tue Dec 04, 2012 8:38 pm
No it properly won't.i was thinking going for the 288mm disc as the standard skyline disc was 280x30mm so 288x28mm isnt that far off.just change the pads before they the pistons pop out.
It fit straights onto the hub.yes it needs redrilling to 4x100 but has a 34.1mm hat height so very similar to standard.
Do you think this will work?
keri-WMS
Tue Dec 04, 2012 10:35 pm
I honestly can't say!
Lurch320i
Tue Dec 04, 2012 11:25 pm
Ok no problem.thanks for your input :-) I will prob buy one of your kits for the rear as i can't find any discs that will fit and keep the handbrake standard.
What sizes are your rear brake kits? 290x?mm
keri-WMS
Tue Dec 04, 2012 11:32 pm
The rear kit is 290x19. :-)
Lurch320i
Tue Dec 04, 2012 11:41 pm
That sounds cool.how much is the rear kit?i will be interested in purchasing a set of rear discs at least as i want to have matching calipers all round.
keri-WMS
Tue Dec 04, 2012 11:50 pm
It's up for review when I get another batch of calipers made, I've got a few brackets and just 1pr of discs on the shelf from memory.
It's roughly the same cost as the front kits, the discs take so much work to make them fit that they make up for the smaller/cheaper rear caliper!
Lurch320i
Tue Dec 04, 2012 11:55 pm
Ok no problem.so how much for the rear discs and a set of custom front discs.around 280-300x30mm.whatever is easier for you to get hold pf
thanks
keri-WMS
Wed Dec 05, 2012 12:14 am
Rear 290x19 E30-fit modified are £160.25+vat/pr, 298.5x24 front E30-fit discs (the biggest we do) are £101.71+vat/pr.
I've got a pair of Audi TT 312x25 discs sitting on a shelf that might be more like you're looking for?
Lurch320i
Wed Dec 05, 2012 3:34 pm
I will possibly have a set of rear discs from you depending on how my Christmas shopping goes.May see what other discs i can use at the front as i need at least 28mm thick so the caliper doesn't loose its pistons
Lurch320i
Sat Dec 29, 2012 9:28 pm
Just a quick update.i read on e30tech that massive lee has said that the citroen 28mm disc will work.its got a 66mm bore and is near perfect offset.so Ive just ordered a set from the local parts place.and a machinist mate is ready to make up the brackets when i have exact measurements.when its done i can get more made for anyone who may want some
will update soon
Lurch320i
Sat Dec 29, 2012 9:29 pm
Its here is anyone wants to read
http://www.e30tech.com/forum/showthread.php?t=104313
post number 8
