Well said! If you don't believe this, try discussing your idea with your insurer..!Grrrmachine wrote:Let's nip this in the bud:
Suspension is a critical aspect of any car, and for the rear end twitchy nature of the E30 correct suspension is critical if you want to keep your wheels on the asphalt and your head facing in the right direction.
While BMW set up the car for the right balance of comfort and performance, people adjust their suspension depending on their specific needs, whether its increased comfort or increased performance. But either way it means buying the correct parts for the situation.
To that end, each component is critical. Each shock and spring has to support 300kg of weight, a quarter of the car, on a steady even path while the wheels are bouncing up and down to the road conditions. Lowering springs reduce the height of the suspension, and therefore the amount that the wheel can move up and down, but to compensate they use thicker steel so that they can still carry the weight of the car.
Butchering a normal spring means that you're removing that much strength from the suspension; when the wheel hits a bump it will be launched upwards, effectively punching the car from underneath, and you've removed the car's ability to absorb that shock just because you want to be cool in front of your mates.
This will ultimately mean that a raised manhole or a nasty pothole will send your car fishtailing. If we're lucky, you'll crash into a tree and only kill yourself, but knowing Sod's Law you'll take out a family of three on your way, killing them and saving yourself. Just because you wanted some stance, some lows, the right profile to make your car look sick, innit.
It's only a 316, and it's only a manky old Beemer, but it's still a 1.2 tonne killing machine and it demands a certain degree of respect. Taking an angle grinder to the springs is just plain stupid.
Lowering 1986 E30 316
Gert_8
snakebrain
+1Gert_8 wrote:Well said! If you don't believe this, try discussing your idea with your insurer..!
This whole thread is stoopid..
bab-91
I can't get over Verde telling someone off.
I'm in shock...
I'm in shock...
IG - bab91
IG - bab91
Gert_8
Look at the Ops user name - says it all.....! Yes, I know he means dope in a different sense, but I'm old school
DopeE30
Shut up you fucking lame, bet your a middle aged broke cunt, that sits at home bashing of this forum. Go to work and spend your whole months wage on your shitty car....Again. And my car is 10 times cleaner then yours you prick. And who said i was going to cut original springs anyways ? Dick.Grrrmachine wrote:Let's nip this in the bud:
snakebrain
You're an oik with a (not quite) slammed 316. Do one.DopeE30 wrote:Shut up you ******* lame, bet your a middle aged broke ****, that sits at home bashing of this forum. Go to work and spend your whole months wage on your shitty car....Again. And my car is 10 times cleaner then yours you prick. And who said i was going to cut original springs anyways ? Dick.
bab-91
You forgot to say your Dad is bigger than his Dad & your Dad will batter his Dad.DopeE30 wrote: . And my car is 10 times cleaner then yours you prick.
ooo A clean 316i.. I didn't realise I was amongst monied aristocrats ...
for who else could own such a spiffing example of engineering.
Andyboy
- Alpina Colada
My word - what an erudite riposte. Your user name precedes you...........would never have guessed how clever you are.DopeE30 wrote:Shut up you ******* lame, bet your a middle aged broke ****, that sits at home bashing of this forum. Go to work and spend your whole months wage on your shitty car....Again. And my car is 10 times cleaner then yours you prick. And who said i was going to cut original springs anyways ? Dick.Grrrmachine wrote:Let's nip this in the bud:
we love retarded knuckle heads on here
+ a yard full of scrap turds
Duke137
Fooking hell Mick, that mineral blue car looked gash
BTW you bunch of snobby bastards!
my old turd was treat the way it lookedDuke137 wrote:********* hell Mick, that mineral blue car looked gash![]()
Mick was going through his council phase
Andyboy
- Alpina Colada
Those were the days. It's all hoity toity these days, cucumber sandwiches and drinking tea with a crooked finger.pacerpete wrote:
- E30 Zone Meets/Events Team
What you mean "Was", he still is.pacerpete wrote:Duke137 wrote:********* hell Mick, that mineral blue car looked gash![]()
He's now moved upto "Pikey Council" phase.
Duke137
Is the mineral blue car the one you fragged 'spreadsheet style' ?
Grrrmachine
- E30 Zone Wiki / Team Member
Not quite sure what your point is, but I understand you're angry. That's fine, let it all out. And breathe.DopeE30 wrote:Shut up you ******* lame, bet your a middle aged broke ****, that sits at home bashing of this forum. Go to work and spend your whole months wage on your shitty car....Again. And my car is 10 times cleaner then yours you prick. And who said i was going to cut original springs anyways ? Dick.
We're trying to save your life here, and that of others. Bodging a car in the way you're asking about is playing with fire. It's nothing to do with penis size or shiny paint or being an internet hardman.
But talking with that sort of mouth won't do you any favours.
how's snoopy hanging rav
Still there Mick,magpie wrote:how's snoopy hanging rav
kangman
I've lowered my car 60mm all round, going to put e90 top hats to lower the front a tad bit more some day.
My car had 45mm front struts and i had them replaced with the donor cars 51mm front struts (318is conversion). On the rears i have stiffer dampers which is a must if your running wide/dishy wheels plus i have rolled my rear arches.
My cars not my daily and ive covered less then 100miles since lowering it. I have driven only over one speed hump and i was running 17s, so im yet to experience it running 16s and 15s
If you want to lower your car more then 40mm, i would invest in stiffer dampers as it will reduce it bouncing and catching. If you have the extra cheddar then buy a good quality set of coilovers.
MY FACEBOOK PAGE- CLASSIC STANCE
http://www.facebook.com/pages/Classic-S ... 6444884427
MY FOUR EYED BEAST
MY FOUR EYED BEAST
The University of Penge has recently finished an in depth research project into vehicle ride height and intelligence. The findings were conclusive, the lower ones car , the lower ones IQ.
You only need to read through the regular "What coiloverz" "How low can I slam my 316" "How do I stop foooking my sump?" to realise that the findings are hardly suprising and pretty obvious and that they could have saved
their £1.4 mill
their £1.4 mill
maggspower
- Turbo Farmer Tractor Driver
Interesting, I was wondering Pete do you have any springs to raise my car up?pacerpete wrote:The University of Penge has recently finished an in depth research project into vehicle ride height and intelligence. The findings were conclusive, the lower ones car , the lower ones IQ.
their £1.4 mill
dazleeds
- old skool raver
Grinder
not that i have ever done such a thing
www.oldskoolfantasy.co.uk
maggspower wrote:Interesting, I was wondering Pete do you have any springs to raise my car up?pacerpete wrote:The University of Penge has recently finished an in depth research project into vehicle ride height and intelligence. The findings were conclusive, the lower ones car , the lower ones IQ.
their £1.4 mill
The findings on their study into " What sort of person owns a Gimp and admits to it in polite circles, or on the zone" have not been released yet , so don't get cocky !
Andyboy
- Alpina Colada
Sadly, that's the Zone these days. It's now degenerated to the point where there are very few posts worth reading. This one is a prime example - do you humour these Mongs, or get hating?pacerpete wrote:
oldroydsr4
This may well be the case, but there is also a very Luddite view from some of the older zoners that become very aggressive towards the questions.Andyboy wrote:Sadly, that's the Zone these days. It's now degenerated to the point where there are very few posts worth reading. This one is a prime example - do you humour these Mongs, or get hating?pacerpete wrote:
May I suggest a Zone wiki is written to clearly run the new 'stance' based users through how to get an e30 to there desired ride height, but also indicate the side effects to a form over function ride height.
Gert_8
Why would we want to do that - more cars that are scrapped the better. Fewer chavs, even more so. Double win!oldroydsr4 wrote:This may well be the case, but there is also a very Luddite view from some of the older zoners that become very aggressive towards the questions.Andyboy wrote:Sadly, that's the Zone these days. It's now degenerated to the point where there are very few posts worth reading. This one is a prime example - do you humour these Mongs, or get hating?pacerpete wrote:
scjimbo
Darwinian theory in actionGert_8 wrote:Why would we want to do that - more cars that are scrapped the better. Fewer chavs, even more so. Double win!oldroydsr4 wrote:This may well be the case, but there is also a very Luddite view from some of the older zoners that become very aggressive towards the questions.Andyboy wrote: Sadly, that's the Zone these days. It's now degenerated to the point where there are very few posts worth reading. This one is a prime example - do you humour these Mongs, or get hating?
oldroydsr4
I know I'm wasting my breath but you can lower an e30 alot and still retain a level of driveabilty (admittedly not to the level of a standard e30 on balloon 14's) , using an adjustable beam shortened shocks, lifting the engine, install sump guard etc etc.scjimbo wrote:Darwinian theory in actionGert_8 wrote:Why would we want to do that - more cars that are scrapped the better. Fewer chavs, even more so. Double win!oldroydsr4 wrote: This may well be the case, but there is also a very Luddite view from some of the older zoners that become very aggressive towards the questions.
All this info would surely help - You can choose to use the info or not.
Gert 8 - with all due respect a cabby with BK's and eye brows - falls in to the same 'chav' category as a stanced e30 .lol.
Gert_8
[quote="oldroydsr4"
Gert 8 - with all due respect a cabby with BK's and eye brows - falls in to the same 'chav' category as a stanced e30 .lol.[/quote]
I agree. That's why that is a very old pic...Brows gone & BBS recently purchased. Also raised on eibach springs and the appropriate shocks.
Gert_8 wrote:[quote="oldroydsr4"
Gert WAS a stancec0ck, now he's just a c0ck
PS BBS spanner en route, you foooking executive !
Gert_8
pacerpete wrote:Gert_8 wrote:[quote="oldroydsr4"
PS BBS spanner en route, you foooking executive ![/quote]
I couldn't help it - that's what the previous c0ck had done to it. I've saved it...
Thanks Pete!
Green
Well this quickly went down the usual route
Out of curiosity, who has cut springs before and had a bad experience?
scjimbo
Personally I have not cut any springs. However I knew a guy who had a 323 E21Green wrote:Well this quickly went down the usual route![]()
He chopped a shed load out of the springs. The result was the biggest abortion I have ever seen. The poor old thing dragged its sorry ass around until eventually the fuel tank wore through.
It was a very sad end to an amazing car.
Andyboy
- Alpina Colada
when i bought my mineral blue one i jacked the back up and the springzz fell out so i bought some uncut ones from a scrapyard but only to find out after fitting that touring springs are different
it was ok for a while coz starsky and hutch is cool innit
