Gareth on here blew his, bent the whole casing
M30 install into calypso cab. Back on the road :)
- E30 Zone Meets/Events Team
That smallcase diff won't last 5 minutes!!!!
jimbom30cab
- Tech 1 freak
flippin heck !! but not really suprised, i've not got round to researching the diff options yet....just taking my time doing the engine and then working backwards which is code for spreading the cost !!
What you need depends on how the car is to be used.
Everyday use, 3.46 or 3.64
Road and track use, 3.73 or 3.91
Bristol_Jer
I've got a 3.73 in mine, but it is a track car. With road tyres on I can do rolling burnouts pulling away in 2nd, don't need to bother with 1st
mcbonio
I can't remember what mine is, 3.46 or 3.73. I have a usable 1st gear but I can also burn out in 2nd and spin wheels whilst moving in 3rd.!
jimbom30cab
- Tech 1 freak
bl**dy hell that sounds fun !! ok have to admit i'm feeling the need for a torquey cruiser in the cab so think i'll go with low ratio, 3.46 or lower, will keep my eyes peeled and do some swatting up on what will fit in the car as i've read there are small, med and large sizes.
Put a 3.64 in the cab.
I have a 3.46 but i do motorway mileage
jimbom30cab
- Tech 1 freak
is the 3.64 a small case Rav?
Bristol_Jer
I wouldn't recommend a 3.73 for a road car personally, but it's perfect for what I want. Medium case is the one to go for, a 325 diff of some description
3.64 comes only on largecase.
Bristol_Jer
I had a medium 3.64 before my 3.73, I thought large case diffs were fitted to e28 535s and similar?
I meant medium
mcbonio
Its a lot of fun Jim, I've had mine running for 2-3 months now and the novelty still hasn't worn off.! I just can't help but thrash it.
jimbom30cab
- Tech 1 freak
awsome !!! got any pics ?
jimbom30cab
- Tech 1 freak
Progress on the engine this week has mostly been cleaning old oil off the block, old gasket stuff and getting the block ready for painting. Shed loads of white spirit, scrubbing and wire brushing later its looking much better, although the garage looks trashed !! I'll get some pics up soon. I've cleaned up and bagged up all the components and just have the front timing chain cover to remove so i can get the chain, guides and stuff out. I'll get the oil pump and chain off today also. My garage is looking like an M30 parts store !!
jimbom30cab
- Tech 1 freak
loads of scrubbing with white spirit and then wire brushing bought the block back to bare metal and then a coat of satin black hammerite. couple more coats and it should look good.
flywheel end which was literally coated in thick oil, none of this was visible at all. White spirit and an old toothbrush bought this up nice, new oil seals in order i think!!
leeparkes
Sound, The colour i used on mine was Hammerite aerosol hammered black, it comes out more a charcoal colour.jimboe39540i wrote: Spent ages looking at peoples M30 conversions mostly on here to see what the best looking colours are for the various bits. Lee - your's looks great so i'll probably do something very similar to yours if you don't mind!!!
Goes on really nice with a suprisingly good finish, coming up to 4 years now and still looks good.
staley_turbo
Id replace that rear crank seal while you can get at it. If it was covered in oil then it probably means its on its way out.
jimbom30cab
- Tech 1 freak
i will staley_turbo, i've got one on order and have been swatting up in the Bentley manual
staley_turbo
Good good
I did mine after and its just a pain.
jimbom30cab
- Tech 1 freak
yer i bet, big job.
I would replace every seal on that engine, i'm replacing everyone on mine as a precaution
jimbom30cab
- Tech 1 freak
Hi Rav, funny you should say that, the first batch of stuff arrived today in the post, well worth it i'm sure but not cheap!!! Recognise some bits here !!
Another order on the way from BMW then a load from Matt at ECP. Soon as i get my engine crane back from TPS i can get the lump in the boot of the trusty e39, i found a truck repair garage near work that can take off the cranknut for me, wip it off, take off the lower timing chain cover and send the boxes off for blasting and coating. Think i'll give the oil pump a good clean like you did also.
I ordered a complete Elring H/G set, and most of the seals were in there, and exhaust gaskets.
Taking the pump is not too difficult, should take you about 1hr to do.
jimbom30cab
- Tech 1 freak
right, time to get this block sorted, took it round a local garage and they got the crank nut off pretty quick, i was well impressed, that windy drill did well.
also, this arrived from the stealers, xmas come early for me
so got the crank nut off and then took these bits down to the local blasters to get cleaned up and painted, all in about 20 bits, some silver and black and some just for cleaning up, they charged a ton which is not bad i think
so here chain end in stages
got those gasket faces cleaned up
oil pump to clean up next
really enjoying this stage
Did you not get new chain guides???
jimbom30cab
- Tech 1 freak
yer, both sides mate, did you see the big crack in the tensioner side in the above pics ? Had a good look at the chain and sprocket and they look fine, think i'll re-use them. Just thinking if i should replace the big end and main bearings now...or not ???
No, just looked at the goodie bags, seen them.
I would be replacing all the main bearings and big end bearings if you have it stripped down.
YOu won't find any in the UK apart from the main dealers, and they were quoting me £900 plus vat for those and piston rings.
If yu need some, you'll need to have the crank measured to see if it hasn't had a regrind.
Then PM Maggspower, I got mine thorugh him from America.
jimbom30cab
- Tech 1 freak
thanks, flippin heck that is expensive, for now, i'll check for end float and if its in spec, i'll keep what i have, the lump is a low mileage decent one.
Endfloat is about 1-1.5th, or should be.
jimbom30cab
- Tech 1 freak
thanks, i'll check and report back
jimbom30cab
- Tech 1 freak
The sun was out this morning so took the old turd for a spin.
mcbonio
Looking good, love the colour.!
When you get the m30 in you might need to raise the front end you know, it's gonna get low.
sag
I got mine from the UK . It was around £160 all in for big and main bearings.Rav335uk wrote:No, just looked at the goodie bags, seen them.
jimbom30cab
- Tech 1 freak
where did you get them from sag ??
