anti fog?
Cloggy Saint
Post Sun Nov 04, 2012 2:25 pm
I've a big problem with my touring's glass fogging up when it's raining. I know this usually suggests moisture inside the car but I can't find any wet areas anywhere. Can someone recommend a good product that will deal with this, there's a lot to choose from! Cheers.
maxfield
Post Sun Nov 04, 2012 2:43 pm
Rain X - rain repellent and anti fog. Both awesome products IMO.
Jozi
Post Sun Nov 04, 2012 5:34 pm
[youtube][/youtube]
That looks good too, prob the same as what maxfield suggests
Cloggy Saint
Post Sun Nov 04, 2012 10:52 pm
Cheers, just ordered some rain X from the bay, hope it does the trick.
Morat
Post Mon Nov 05, 2012 9:10 am
Check your passenger footwell carpet (under the mat if you have one) and feel around behind the centre console. Condensation in my touring was the first sign of what turned out to be a failed heater matrix valve. I couldn't find any leaks or water, but the carpets hold an incredible amount of liquid before they feel anything more than a bit clammy.
Eventually I found the heater matrix valve was leaking just enough to make a drop on the lowest part of the plastic which you could feel when you touched it.
Mine was sorted with a good second hand valve and a couple of hours labour.
Post Mon Nov 05, 2012 9:42 am
As Morat says, your problem is an indication of a deeper problem. E30s have an exceptionally well designed ventilation system, and there shouldn't be any problem with misting windows.
Cloggy Saint
Post Mon Nov 05, 2012 1:47 pm
I'm pretty sure it's all dry around the foot wells but I'll check again. The misting is confined to the rear windows and the boot space glass.
Rich320I
Post Mon Nov 05, 2012 1:54 pm
no water in the boot then bud? mine did that until i replaced the light gaskets on the rear. there was the smallest amount of water collecting in the left hand pocket but it was enough to mist the rear window up.
polsta
Post Mon Nov 05, 2012 2:48 pm
its water in the car somewhere mate
lift up the rear footwell carpets, feel underneath and see if the foam is damp/wet , and check the big round bungs in the floorpan if any moisture there , when they start to go they can let water/damp in, which is slowly absorbed by the foam
check the inner arches behind rear door cards- a hole in there would let water spray in
and remove all boot carpets and have a good look for damp
on another note- i recently tried autoglym glass polish, f**k me its wonderful stuff, gives a real nice shine and clarity to the glass, and it lasts ,and makes abig difference in it misting up and keeping clean, excelletn on outide of the windows too, very highly recomended stuff
Cloggy Saint
Post Mon Nov 05, 2012 3:50 pm
If there was water inside then I guess the glass would fog up even when stationary but it only happens when I'm in there driving.
Morat
Post Tue Nov 06, 2012 1:27 pm
When it gets warm....
Cloggy Saint
Post Tue Nov 06, 2012 1:50 pm
Just gave it another inspection and there's a very small amount of water in the left side boot space "cubby hole", but literally just a few drops...
Morat
Post Tue Nov 06, 2012 2:39 pm
It's got to be something else, my touring doesn't mist up even when one of the rear cubbies has 3 inches of water in it! Vapour is what you're looking for...
Cloggy Saint
Post Tue Nov 06, 2012 3:09 pm
Kinda hard to look for vapour :?
Morat
Post Tue Nov 06, 2012 3:49 pm
I know, took me ages :(
But it's got to be there somewhere!
Post Tue Nov 06, 2012 5:09 pm
My Sport had terrible condensation, removed the carpets and was soaking wet on the passenger side, turned out to be rotten under fuse box, had this all welded up and put carpet back in once dry and problem cured :D
Cloggy Saint
Post Thu Nov 08, 2012 11:33 pm
I'm at a loss :( . I can't find the source of this damn condensation. The boot space is pretty much bone dry apart from the slight damp in the storage compartment. The front footwells are dry and there's no sign of any water coming from the heater matrix and I know the bulkhead's solid. Where/what else to check??
Post Fri Nov 09, 2012 7:04 am
Sweaty heater matrix or valve? May not cause wet carpets but if it's starting to sweat (leak) then as it gets hot, theres your vapour.
Ever get a faint smell of Antifreeze?
Post Fri Nov 09, 2012 7:20 am
Ed, your car has factory air con right?
Check that the 3 evaporater drains are not blocked. If you have been using the air con, especially to demist the condensation then water will be building up indside the evaporater and condensation will rise up through the dash top vents causing the misting.
capnmchl
Post Fri Nov 09, 2012 8:50 pm
polsta wrote: ......
Another good product is Wurth Active Glass Cleaner. Expensive, and not technically a polish, but by god it cleans windows well.
Much easier to use than a normal polish as well.
Cloggy Saint
Post Fri Nov 09, 2012 11:47 pm
bss325i wrote:Ed, your car has factory air con right?
It does have factory AC but I haven't used it for any prolonged period for a while, and probably not since the misting problem started. The evaporater is the drier, yes?
Post Sat Nov 10, 2012 9:51 am
No the evaporator is the part that air is blown through to make the air cold. Its in the heater box and condensation builds up on it which is why there are drains in the bottom of the heater box.
The drier/receiver is the bottle that goes behind the head light on the RH side inner wing.
