Engine died
StuBeeDoo
Post Fri Nov 02, 2012 11:47 pm
OK, this is a shot in the dark. I'll describe the symptoms.......
For a while, when starting-up warm, my M20 has occasionally revved up to about 2.5k for a few seconds and then dropped back to it's normal idle speed.
This evening, it was a b17ch to start from cold - which it isn't usually - and when it did start it went straight to 2.5k and stayed there. I had to get to work, so I drove it like that for about 5 miles (I know, I know......). Then the engine just died and wouldn't start again. :(
I'm thinking ICV. Anyone got any better ideas??
TIA
Stuart.
Post Sat Nov 03, 2012 12:32 am
welcome back Stu :D
clean up your TPS !!
JGTI
Post Sat Nov 03, 2012 12:36 am
I would check the ICV too!
StuBeeDoo
Post Sat Nov 03, 2012 12:53 pm
e30topless wrote:welcome back Stu :D
Thanks Steve. It's only for the query, though. I can't be doing with all the slagging and flaming. ......And anyway, I've got a time-consuming hobby that doesn't involve E30s.
Back to the problem........ It's sorted. It was the ECU. I haven't opened it up to see if there's anything visual, but the car wouldn't start when I got back to it this morning and when I got as far as swapping ECUs it started straight away. Just as well, as I have a spare of just about everything except the ICV. I really need to get one.
Thank you both for your input. :thumb:
Post Sun Nov 04, 2012 3:02 pm
good to hear your sorted again Stu
