MOT woes.
Sanchez
Post Tue Oct 30, 2012 4:44 pm
MOT finished where shall i start.
needs
2 new front drop links(in stock)
2 new track rod ends
2 new outer drive shaft rubbers(maybe second hand shafts easier, and ideas?)
1 corroded rear brake pipe(urmm i paid for the front to rear and both rear parts to be replaced last year)
2 new rear wheel bearings(had an idea about these anyway(one in stock)
both front headlights aim to low(didnt adjust after replacing rear springs)
and the CO2 is to high.
pass is 3.50 or less my score is 3.55!!!!!!!!!!!!!!!!
and the avisories.
headbrake 16% efficient
windscreen chip passenger side
front copper brake pipes all slightly corroded
front flexi hoses both deteriorated.
All in all not that bad for someone with more time than i have on my hands.
So tips on
rear bearings replacement.
if anyone has a pair of good abs rear shafts ide be interested.
and apart from a service what will help lower CO2?
If got a rich running M20B25 and have been trying to solve this all summer(kinda when ive time).
Any help on the above all welcome.
Peter
Captain_Birdseye
Post Tue Oct 30, 2012 4:52 pm
Oh dear.
Topblag
Post Tue Oct 30, 2012 4:55 pm
If you want to fire over with the car I'll happily lend a hand with the work that needs done. If we get stuck, my loft is full of all sorts and we can borrow bits from the Sport as it's all there.
Let me know, I'm around this weekend if it'll help. I'm down South until late tomorrow night.
Worth talking to James considering he's got a pile of bits lying around and no E30.
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
Sanchez
Post Tue Oct 30, 2012 5:02 pm
Ta Colin. It looks worse on paper but the rolex stops for nobody winkeye
Ive no free weekends for a while now. James just txt me.
Post Tue Oct 30, 2012 7:22 pm
Rear wheel bearings are a bitch - I would take the trailing arms off, take them to a garage with the new bearings and get them to press the old ones out and new ones in.
For emmissions put a new air filter in and take it for a proper blast before the retest
could be blue temp sensor if its running rich ?
hennabm
Post Tue Oct 30, 2012 7:24 pm
Sanchez wrote:MOT finished where shall i start.
needs
both front headlights aim too low(didnt adjust after replacing rear springs)
and the CO2 is 3.55!!!!!!!!!!!!!!!!
So tips on
Peter
First of all the rear drive shaft boots are NOT part of the test so the car has been incorrectly failed for that item. :x
However, of the correct fail criteria has been applied to the wheels bearings ie
1.Excessive roughness in a rear wheel bearing.
2. Excessive play in a rear wheel bearing, indicating severe maladjustment or wear.
Then this is an ideal opportunity to replace the boot/s. :wink: IIRC the rear bearings require some force and sometimes a little heat to undo the nut and persuade them to part.
The air cleaner and a check of the plugs may well help you to get below the limit. Although I would think that a std 325 would be well below, probably around 1.5%.
Which brake pipe is it? Pipes even made of monkey metal normally would last more than a year :mad:
'82 323i henna
'10 116d Sport Red - MkI
'11 X3 3.0d SE
'89 240 DL Estate
Sanchez
Post Tue Oct 30, 2012 7:39 pm
Rear arms will come off and bushes get pushing in via garage 10 tonne press ive decided.
Rear pipe is the small one on the trailing arm that didnt get replaced.
Service and wee blast seams to be the order of the day.
Yep rear bearings failed as mentioned above.
sag
Post Tue Oct 30, 2012 7:45 pm
They are a failure . It's one of the many new failures which were added early part of this year
maxfield
Post Tue Oct 30, 2012 7:46 pm
All boots and gaitors are now part of the test according to my MOT man. And I've used him for the past 5 years on many cars
Rtaylor2208
Post Tue Oct 30, 2012 7:57 pm
Can you elaborate on how the CV boots are not a fail? Mine failed on the same last year and I had to pay to have the boot replaced. If you don't mind me asking are you a MOT tester?
sag
Post Tue Oct 30, 2012 8:03 pm
Rtaylor2208 wrote:Can you elaborate on how the CV boots are not a fail? Mine failed on the same last year and I had to pay to have the boot replaced. If you don't mind me asking are you a MOT tester?
It shouldn't have failed last year. If you are talking about a e30. As the rear drive shafts went part of the test. Only the front outer ones were
As of january this year the rear drive shaft gaiter became a fail and the front inner gaiters aswell
> Any drive shaft support bearing excessively worn or a coupling gaiter missing or no longer preventing the ingress of dirt etc.
tomislav
Post Tue Oct 30, 2012 8:15 pm
All the new boot failures that have come in are to do with 'preventing the ingress of dirt'.
If the boot has a pin hole then its not really a fail.
If its blatently flailing around in the wind the dirts gonna get in and its a fail.
And last year it shouldn't have failed, sag is right.
Yes i'm an MOT tester.
Hope that helps
Sanchez
Post Tue Oct 30, 2012 8:19 pm
As above its a new test this year.
Tom fancy sending me a fresh ticket nice Mr MOT Man winkeye
tomislav
Post Tue Oct 30, 2012 8:24 pm
Love to mate but it'll cost you 25k a year (for when i lose my job and you have to reimburse me lol) :D
To be honest, the stuff your car has failed on is a godsend, no mention of rust on it anyway. Much rather a mechanical repair on an e30 than one thats rot related.
The drop links and the rod ends can be had new from gsf for peanuts and they're normally lemforder items.
Granted the rear wheel bearings are a pig, maybe just get 2 rear trailing arms off the zone, complete with bearing and do it that way? Got some in my garage!
Sanchez
Post Tue Oct 30, 2012 9:42 pm
Dont worry i prefer a legit MOT as at least the cars getting better than getting worse which is my aim.
I knew the rust was ok. Like you say its not all bad.
It looks worse on paper.
hennabm
Post Wed Oct 31, 2012 12:09 pm
The changes that occurred in January this year brought into the test the inner CV gaitor/boot on front wheel drive vehicles.
The gaitor/boot on rear wheel drive shafts only apply when the drive shaft forms part of the rear suspension, which it does NOT on an E30.
Referring to the MOT testers manual;
Section 2.5 of the manual deals with FWD vehicles.
Section 2.4 (last page) deals with RWD vehicles. The clue is in the Method of Inspection "on vehicles which have a drive shaft which forms part of the suspension" :wink:
'82 323i henna
'11 X3 3.0d SE
'89 240 DL Estate
Post Wed Oct 31, 2012 12:19 pm
Its a bit scary the amount of testers out there who are not doing their job properly! :(
And listen to hennabm, he know's what he is talking about!
Post Wed Oct 31, 2012 12:21 pm
Fitterzzzz ! :(
tomislav
Post Wed Oct 31, 2012 4:04 pm
I'm gonna go double check everything cos i'm doubting myself now?!?!?!? 8O
Post Wed Oct 31, 2012 4:20 pm
Another thing ive heard of is people getting failed for having HID's with out having self leveling adjusters and a wash device.
Those reasons for refusal (ie reason to fail) have not come into effect yet despite what the internetz would have you believe.
hennabm
Post Wed Oct 31, 2012 7:50 pm
:x :x :x :x :x :x :x :x :x :x :roll: :roll: :roll: :roll: :roll: :roll:
'82 323i henna
'11 X3 3.0d SE
'89 240 DL Estate
