WMS Brakes: 4 pot race / trackday brake upgrade kits
Traders Section
kam325itouring
Wed May 09, 2012 12:09 pm
Tried the template. There is enough clearance on 17" lensos :D
All Car Audio - Approved Alarms - HID Kits - Custom Boot Installs - All jobs considered
keri-WMS
Wed May 09, 2012 2:36 pm
Cheers Kam, handy to know! That's the 4P028 one? And what width/offset Lenso?
kam325itouring
Wed May 09, 2012 10:40 pm
keri-WMS wrote:Cheers Kam, handy to know! That's the 4P028 one? And what width/offset Lenso?
Yeap the 4P028. 7.5 x17 et20
keri-WMS
Sun May 13, 2012 10:01 pm
Cheers Kam, noted away in the WMS databanks! :cool:
Kedge
Thu Jun 21, 2012 5:56 pm
PM sent Keri.
Instagram - Kedge85
keri-WMS
Thu Jun 21, 2012 6:16 pm
On it!
e30max
Tue Jun 26, 2012 7:08 pm
pm'd
Francisco
Tue Jun 26, 2012 7:22 pm
Keri, for God's sake when are building a damn 305 mm, 4 pot kit for the M3 to be fitted under BBS 16' (extra 7mm thick bells - 14mm total) like the AP kit from BG developments??
keri-WMS
Fri Jul 06, 2012 12:45 pm
We don't have a caliper that will sit at 305mm on the M3 (5 stud BMW stuff all has lugs that get in the way!), we have designed a radial mount one to clear cars like this but it's not in production yet.
If it was simply a case of design brackets and bells we'd have done it ages ago!
Theo
Sat Jul 07, 2012 10:21 pm
Keri, you have pm
reggid
Sun Aug 05, 2012 12:55 pm
keri-WMS wrote:
I've been working on bias a bit recently, ONLY as a simplified "brake setup vs brake setup" comparison, not an overall car study - so this ignores everything other than the caliper/pad/disc.
Here are four examples, interesting results I thought!
Standard E30 saloon (not Touring!)
...fitted with 280mm disc / 1.25" piston WMS kit:
...fitted with 298.5mm disc / 1.25" piston WMS kit:
...fitted with 280mm disc / 1.38" piston WMS kit, this is the earlier spec and is still available for people wanting more front bias inside the 15" BBS (due to running semi-slicks for instance):
does this mean the 280mm kit has less braking torque than stock (37.7 vs 38.9)?
E30 325is with M20B31
keri-WMS
Sun Aug 05, 2012 1:17 pm
The aim isn't to increase torque because that could upset the brake balance - BUT if you do want more front bias simply opt for the 1.38" piston size, that gives you a number of 45.9 as shown in the last table you quoted. Hope that makes sense!
reggid
Tue Aug 07, 2012 2:51 am
keri-WMS wrote:The aim isn't to increase torque because that could upset the brake balance - BUT if you do want more front bias simply opt for the 1.38" piston size, that gives you a number of 45.9 as shown in the last table you quoted. Hope that makes sense!
i would have though more torque and then bias adjust would be the go, depending on suspension/tyres the stock bias may not be ideal. I realise there is more thermal mass to reduce fade etc but my hate is the pedal feel and the lack lustre initial response. How much difference is a stiffer caliper and braided lines gonna make?
reggid
Tue Aug 07, 2012 2:57 am
what about the 735i M/C is this recommend with one of the kits? i understand it might also adjust the bias but i am not sure whether towards the front or rear
321gazza
Sat Oct 06, 2012 9:07 pm
hi keri, can you pm me a price on a front brake set up, using your 298mm kit for my e30 and brake pads, i have a 2.0ltr turbo engine fitted and is only for road use, im running 16" wheels with a 21mm offset and have a pedalbox fitted so can adjust the bias, dont need the brake lines as will need to get custom one made anyway, many thanks.
keri-WMS
Sun Oct 07, 2012 12:25 pm
reggid wrote:what about the 735i M/C is this recommend with one of the kits? i understand it might also adjust the bias but i am not sure whether towards the front or rear
I've not got the specs for the 735i m/c, but our kits are designed to work the OEM-fit one. You can probably use the 735i one but there's no reason to!
321gazza wrote:hi keri, can you pm me a price on a front brake set up, using your 298mm kit for my e30 and brake pads, i have a 2.0ltr turbo engine fitted and is only for road use, im running 16" wheels with a 21mm offset and have a pedalbox fitted so can adjust the bias, dont need the brake lines as will need to get custom one made anyway, many thanks.
Will do!
Black_Potato
Tue Oct 30, 2012 11:38 am
Keri, are you alive and kicking ?
I pinged an email with details of a potential order but I cant seem to get a reply. If you have it can you please reply.
Ta.
3x S14 Rightness....
keri-WMS
Tue Oct 30, 2012 11:53 am
Sorry about that - was that on Friday?
I'm buried under a VAT return but will get back to you properly today!
Black_Potato
Tue Oct 30, 2012 1:16 pm
Hi Keri,
Sent to keri@wms-brakes.co.uk on 26th. I will send it again now.
keri-WMS
Tue Oct 30, 2012 2:26 pm
Yup, friday/26th - I got today's one too, I'll reply now. :-)
keri-WMS
Thu Dec 06, 2012 3:58 pm
I've updated the wheel vs WMS brakes list in post #1, I've found that for those with a spacer fetish you CAN fit the 298.5x24mm kit behind the 15" BBS (tested on the FPS casting version), but you need 20mm minimum and really 21/22mm.
So if that's your thing, it will fit! Here's the profile in the wheel, with a "20mm" spacer:
Thu Mar 07, 2013 5:25 pm
keri-WMS wrote:I've updated the wheel vs WMS brakes list in post #1, I've found that for those with a spacer fetish you CAN fit the 298.5x24mm kit behind the 15" BBS (tested on the FPS casting version), but you need 20mm minimum and really 21/22mm.
I think ive just found something else for 'the list' :D
No doubt rears will follow too at some point :)
keri-WMS
Fri Mar 08, 2013 1:33 pm
Sweeet! :D
I thought I'd mention that this is possible with a spacer as a it turned out a competitor was saying their kit "fits under the BBS" - but needed a huge spacer which is far from obvious!
So the point is that if you are happy to run spacers (so a like-for-like comparison) we out spec them in terms of what's possible so I thought I'd make that clear.
Fri Mar 08, 2013 1:35 pm
Sent you a pm about it :wink:
keri-WMS
Fri Mar 08, 2013 1:38 pm
Yup - just looking up the bracket prices etc to send back! :D
Fri Mar 08, 2013 1:43 pm
:thumb:
tomislav
Sun Mar 10, 2013 9:37 pm
Dan, you used these before? Any good?
To the OP, i had wilwood midlites, 4 pots, 310mm discs before and they were immense. Need something to rival these.
Will be running 17's so big discs not an issue.
Could you price me the biggest discs, calipers and hoses please and also some race pad but i'll take your advice on those. I'm a serious nurburgring tripper by the way and the last of the late brakers so bear that in mind on pad choice please. Ta
keri-WMS
Mon Mar 11, 2013 6:03 pm
tomislav wrote:To the OP, i had wilwood midlites, 4 pots, 310mm discs before and they were immense. Need something to rival these.
Hi, the nearest WMS kit to the one you had is the 298.5mm 4P028, see post 1 for prices (I'll also drop you a PM).
In terms of pads I would say DS2500 based on their feedback, or if it's race ONLY I have a few types of Hawk full race pad on the shelf.
If you have a look at post 1 there's also a printable PDF for each kit you can use to test wheel clearance.
PM to follow! :D
400motor
Tue Aug 13, 2013 6:11 pm
hi,
not sure if you got my pm, looking to purchase your 280 kit if you could pm me thanks
gary
keri-WMS
Thu Aug 15, 2013 2:02 am
PM replied to.. :D
Click_Here
Wed Oct 09, 2013 8:10 pm
Whats with 2-pot 290mm rear breake kit? Price?
keri-WMS
Sat Nov 02, 2013 2:40 pm
Click_Here wrote:Whats with 2-pot 290mm rear breake kit? Price?
Do you mean what is included? The basic "kit" is:
- Calipers
- Discs
- Caliper mounting brackets and bolts / nuts etc
The parts available separately are:
- Pads
- Lines
Price depends partly on how we go about making the next rear batch, but probably in the region of £425.00+vat (+/- 10% ish)
dot
Sat Nov 02, 2013 4:54 pm
I may well be up for one of these rear kits if the opportunity arises a‘‚
Chassis twist!
anothere21323i
Tue Nov 12, 2013 10:34 pm
PM'd :D
keri-WMS
Wed Nov 13, 2013 1:14 pm
Replied! 8)
Locked
