I've fitted a new water pump and cambelt to an M20B25, everything it torqued up correctly and a new paper gasket has been used with the pump.
Thing is water is leaking quite badly from between the pump and the block. Could this be a duff pump, rubbish gasket or something else?
Stupid Question Regarding a Brand New Water Pump Leaking
Kedge
- E30 Zone Meets/Events Team
Did Matt supply it
maxfield
Did you clean everything up properly?
Or the gasket be misaligned, easy done?
kam-325i
Either some crap left from the old water pump gasket on the block, the new gasket or the mating face on the new pump...
Kedge
No commentRav335uk wrote:Did Matt supply it
Yea pretty sure it all had a good scrub beforehand, might be worth pulling it apart and checking the gasket again. Good few hours wastedmaxfield wrote:Did you clean everything up properly?
bmw9818
i wet and dried the surface and used a thin layer of sealant on both sides of the gasket when i did mine,
Very easy to 'miss' one of the bolt holes in a M20 water pump gasket when fitting it. Even more so if you're trying to fit it while fighting the belt tensioner spring.
