Valves were vacum tested to test for any leakage.
Rav's Chromie, Bodywork time
- E30 Zone Meets/Events Team
Cheers Mcbonio
Impressive work, but I hope that isn't a hairline crack in that valve seat, towards the top right:
I'll take a look tomorrow, but Byron did inspect it thoroughly before I got it back.
maggspower
- Turbo Farmer Tractor Driver
No its a very small pube, they get everywhere dont theySpeedtouch wrote:Impressive work, but I hope that isn't a hairline crack in that valve seat, towards the top right:
You didn't go shoving your little willy into the holes Byron
maggspower
Like I said give it a good wash
PMed
PMed
LOL, got it mate.
It'll be on it's way.
leeparkes
Nice.
More pics to come tomorrow Lee.
goosiegander
- Zonegoose
Why Thank You Goosie.
Nice to see you have somebody that knows what theyre doing on the case Rav
maggspower
Yes not bad for my first goDanThe wrote:Nice to see you have somebody that knows what theyre doing on the case Rav
This was your 3rd attempt!maggspower wrote:Yes not bad for my first goDanThe wrote:Nice to see you have somebody that knows what theyre doing on the case Rav
leeparkes
Where's these pics Rav?
I'll update tomorrow, didn't get alot done today due to time.
zaust
- Zone day release
Cheers Marc,
should be at the garage for about 11 today.
Will carry on building up the bottom end.
Only a small update to keep you happy.
Firstly, all new chain guides fitted yesterday,
New thrust bearing and shells fitted, dropped the crank in and tightened up the bolts.
For some reason, there was quite alot of end float which was a bit baffling, as everything was measured by using a micrometer
So off came the crank again, the old thrust bearing installed, and then everything reinstalled again, this was to check the origional end float on the crank, cam to 0.005th
So, vice versa, new one installed, and for some reason, don't ask, there was reduced crank end float to about 0.002th, so checked and rechecked, phoned a few guys on the Zone to make sure and all is now ok.
jimbom30cab
- Tech 1 freak
nice one Rav, how did you get that crank shaft nut off - the mega tight one ??
Loads of heat, and a 3/4 Snap On impact Gun, still took about 10 minutes though.
That was lucky.
Nest time I will leave the flywheel on
it'll help lock up the crank
That was lucky.
jimbom30cab
- Tech 1 freak
cheers mate. i've just picked up a B35 nice head and a shrick cam, so sending the whole lot off to Corry's to be re-furbed, i'll put some pics up when i get back. Still keep thinking about that B2B for sale on here but just can't justify the £££.
Seen it, looks a nice kit.
I'm thinking about it too
Had a little time to spare today, so got on with putting the pistons back in.
Oil'd up the bores, and put in all the pistons one by one.
The block was then turned over, new shells fitted and the rest fitted and torqued up as needed.
Decided to take the Oil pump apart and give it a clean before refitting.
And fitted.
And fitted.
Bristol_Jer
Nice work Rav
Cheers.Bristol_Jer wrote:Nice work Rav
Have now decided not to fit the head on yet, needs to go away for more work
Bristol_Jer
Bigger valves?
Wait for it, wait for it
leeparkes
Lee, did you ever take the head of the Alpina??leeparkes wrote:
mcbonio
Whats the final goal for this doink Rav? Turbo/supercharged?
When funds allow, ITB's and Supercharger.
leeparkes
No but ive been tempted to, Alpina valves are 1mm bigger also the chambers are Hemi style (but mahle pistons to match). This is why i mentioned Kos had a B10 bottom end with the M5 rods etc...
In your shoes id get it running N/A with the ITB's on to see what its like, then boost later when your bored with the power.
It will be plenty quick enough as it is with the mods you have done.
Tuned M30 FTW.
Tuned M30 FTW.
Kos's bottom end
was a thought when you mentioned it, but i'm on a budget
I'm going to run it on the ITB's first, to run the engine in for 500 miles or so, then it's getting boosted if I have funds, hopefully sooner than later.
I would like to see the Hemi chambers of the Alpina head though.
Any links you can think of Lee?
This is the next Head mod.
To match the head inlet ports to the Adaptors for the ITB's
