Repairing glass heater elements
Cloggy Saint
I doubt these repair gloops actually work properly - you're probably best off fitting a replacement screen.
blackrs2000custom
Tried repairing the elements many times and never been succesful, the current seems to burn out any other weak spot after you repair one broken bit.
Finding a good window is also difficult , I have just bought a fifth rear window to try
If you can source a new window I would go for that
Cloggy Saint
New rear glass for a touring costs more than 500 euros and I can't imagine it would be replaced without the spoiler getting damaged. I've tried removing the glass myself in the past and it's just impossible, it's like the entire car has been built around it!
Elements can be repaired successfully and permanently if you use a two part epoxy conductive paint, and are repairing damage rather than generally corroded elements.
Clean the area properly, paint between two strips of masking tape, and make sure you buy the electrically conducting version of the paint, not the heat conducting type.
Failing that, you could try thawing ice on the screen on a cold morning with very hot water.
Or you could fit an aftermarket heated rear window kit:
http://www.ebay.co.uk/itm/mini-cooper-l ... 3f1e021a0e
http://www.jcwhitney.com/clear-view-aut ... ilterid=j1
BenHar
To go with the above, I can recommend: http://www.halfords.com/webapp/wcs/stor ... yId_165574Speedtouch wrote:Or you could fit an aftermarket heated rear window kit:
Ben
