Auto to Manual - been told i need a seal?
l16ydl
Post Sat Oct 20, 2012 12:21 am
I've putting in a M20 325 engine in my car, the engine originally had a auto box on there but im converting it to a manually. I was told that i need a seal to fit on to the crank shaft before install the manual box on, can anyone shed some light on what seal i need and where it goes?
cakey87
Post Sat Oct 20, 2012 12:27 am
its not a seal, its called a spigot bearing, euro car parts do them for about £6.
after you have took the auto gearbox, torque convertor, and ring gear off you will see the output shaft, the spigot bearing slides onto there and needs to be knocked into the space in the crank caseing so it sits flush, i have pics somewhere when i did mine, ill try and find them for you
l16ydl
Post Sat Oct 20, 2012 9:35 am
cakey87 wrote:its not a seal, its called a spigot bearing, euro car parts do them for about £6.
Cheers , if you can get some pics that would be great!!!
capnmchl
Post Sat Oct 20, 2012 10:16 am
There's also 2 metal bits and a foam pad that come up on realoem. I bought them I fitted them when doing my conversion. Don't know if they're needed though.
http://realoem.com/bmw/showparts.do?mod ... g=11&fg=20
1 is the pilot bearing, 2 3 and 4 are the bits i'm on about.
cakey87
Post Sat Oct 20, 2012 10:19 am
There u go matey, the bearing needs to sit flush, dont pust it all the way in.
cakey87
Post Sat Oct 20, 2012 11:04 am
capnmchl wrote:There's also 2 metal bits and a foam pad that come up on realoem. I bought them I fitted them when doing my conversion. Don't know if they're needed though.
as far as i know they arnt needed,
well i didnt out them in and everything is all good on mine, but i did it on a 2.7 block, dont no if theres any difference.
Post Sat Oct 20, 2012 1:41 pm
cakey87 wrote:
capnmchl wrote: 2 3 and 4 are the bits i'm on about.
Correct
capnmchl
Post Sun Oct 21, 2012 12:32 pm
Oh well, I fitted them on mine anyway.
l16ydl
Post Tue Oct 23, 2012 12:04 pm
cakey87 wrote:There u go matey, the bearing needs to sit flush, dont pust it all the way in.
Correct
Cheers guys,picked up the bearing yesterday from Euro for £5.40. Was worried that i would need 2,3 & 4 but cheers for confirming.
capnmchl wrote:Oh well, I fitted them on mine anyway.
Lol, sure they cant do no harm
Andyboy
Alpina Colada
Post Tue Oct 23, 2012 1:40 pm
If they weren't needed, they wouldn't be there. They are basically dust covers to keep clutch dust off them - you will probably get away without them being fitted but the correct bits are a only a few quid. As for fitting the bearing - don't fit them flush to the end of the crank. They need to be driven in about 4mm. If it's not in far enough, the tapered part of the input shaft can put too much pressure on the inner bearing race and quickly ruin it.
Before fitting the bearing to the crank, make sure it is a perfect fit in the input shaft end.
Post Tue Oct 23, 2012 1:49 pm
AFAIK, the original bearing spec. was open sided, and subsequently superseded by one with built in seals. I'm sure that the advice that the parts in question were no longer required came from BMW.
