What I had that I don't think is standards is:
Switch under steering column with a LED in the loom (seems to be cut and goes nowhere)
Red switch next to the heater controls
Single brown wire coming from the rear door area
and a mess of wires I'd like to tidy up.
Here's the switch and LED from under the column and where it goes and ends
Brown wire connects in to the loom behind the rear seat (I think it might be original?) then runs loosely along the inner sill to a sleeved wire (joined by a purple one) and, not 100% sure any more but from there it goes in behind the speaker and/or to a connector block with nothing on it.
I think the connectors could be un-needed as there's nothing on them and also they are a bit messy compared to the neatly wrapped loom around it.
There's also a pair of blue connectors (speakers maybe) that I'm sure aren't original and not really that neat.
Finally this is left over in the bay, can I just trace it back and cut the wires out from it?
So whats the best way for me to go about cleaning this up a little before I wrap it up with cloth tape.
