Tie-Rod end stuck
HJG-E30
Post Sat Sep 29, 2012 3:03 pm
Hi guys,
Replacing my tie rod end on driver's side as there's play in the ball joint. Removed the clamp which clamps it into the inner tie rod, but cannot for the life of me remove the damn outer rod. I've got a 17mm spanner on the inner rod across the flats provided, and positioned such that the spanner is pressing down onto the wishbone as I put a massive load of leverage on the outer rod. And nothing happens; apart from the spanner slipping off! I'm assuming normal right hand thread?!
Post Sat Sep 29, 2012 3:15 pm
replace the whole thing,remove the gaiter and undo the tie rod .
Bristol_Jer
Post Sat Sep 29, 2012 4:35 pm
You can heat the area where the clamp sits with a blow torch, this should get it free, did this on my e30 a couple of weeks ago when I adjusted the tracking.
HJG-E30
Post Sat Sep 29, 2012 6:16 pm
used a big bit of pipe courtesy of an old JD-bug scooter in the end, that got it moving!
maxfield
Post Sat Sep 29, 2012 7:38 pm
magpie wrote:replace the whole thing,remove the gaiter and undo the tie rod .
Best thing, think tie rod only cost me £6. Made life loads easier
Green
Post Sun Sep 30, 2012 4:50 am
Mine were seized on and kept slipping off last year so I used a grinder to make the sides more flat and used a small sized spanner on it.
Whole tie rod is about £47 from Euro's or £25 if you can get it from Meatballs on here 8)
