ECU & Chip help/advice
Staty
My cat is called Dave
Post Fri Sep 28, 2012 8:16 pm
Hi guys and girls, i'm pretty sure the ecu is the correct one for me e30, I've got a pre facelift e30 325i cabby 1988, is this the correct ecu for my car? If so can i chip it? Cheers
Grrrmachine
E30 Zone Wiki / Team Member
Post Fri Sep 28, 2012 9:24 pm
That one's for an automatic 325i from 09/87 onwards, meaning it's Motronic 1.3 and therefore chippable.
For a list of ECUs, check here:
http://www.e30zone.net/e30zonewiki/index.php/ECU
Staty
Post Fri Sep 28, 2012 10:55 pm
But what bearing does this have on that my car is manual? Any at all?
Post Fri Sep 28, 2012 11:42 pm
The 164 is a dual-PCB, early version of Motronic 1.3 and tricky to chip. You're better off changing it for a later and more reliable 173 ECU (a direct swap), such as the one I currently have on E-bay:
http://www.ebay.co.uk/itm/271067045629? ... 1555.l2649
For which I can provide either a Mild or Wild chip, or just keep it with the standard chip that's currently in it.
Staty
Post Sat Sep 29, 2012 9:02 am
Good plug, so i can literally just bolt your one on my car, is there any point in going anything less then wild? How much can you provide it with a wild chip bud? Cheers
Staty
Post Sat Sep 29, 2012 9:04 am
I'm watching it now, so if i win the auction, shall we discuss how much with a wild chip in? winkeye
mcbonio
Post Sat Sep 29, 2012 10:01 am
Buy it outright man, I can vouch for speedtouch, one of his chips just solved my cars running issues. Had the wrong ecu.
Staty
Post Sat Sep 29, 2012 10:21 am
I have read a fair bit of feed back in regards to these chips, from what I've read i'm happy to buy it now for sure! Just watching the ECU on Ebay, so hopefully i win the ecu and he can wack a chip in it and i'll buy it as a whole! :D
mcbonio
Post Sat Sep 29, 2012 7:52 pm
50 quid posted with the chip installed might be a good price... ;)
Staty
Post Mon Oct 01, 2012 1:46 pm
Got an ECU with wild chip on its way, hopefully it does what it says on the tin and is actually wild! Looking forward to giving it a try!
Staty
Post Tue Oct 02, 2012 11:14 am
Purchased the ecu with the wild chip in yesterday, got it this morning, really fast delivery, can't wait to fit it lunch time and have a play!
