Terraclean?
Emm3
Mon Sep 10, 2012 8:30 pm
Anyone tried this on a e30 I assume it's probably better on not so old cars and not ones where sensors etc are worn due to general age and use?
HairyScreech
Mon Sep 10, 2012 8:31 pm
no, just no.
Ive put diesel oil in my m20b25 to clean it out :?:
adit
Mon Sep 10, 2012 8:46 pm
[youtube][/youtube]
[quote="bss325i"]
gman1
Mon Sep 10, 2012 10:10 pm
This seems like good thing.......right?????....if not why?? :eek:
Mon Sep 10, 2012 11:54 pm
What a pair of mongs :)
Ianb
Tue Sep 11, 2012 9:50 am
Dan, If you already think they're a pair of mongs wait till you see the trailer on Discovery for their new series, dressed up as Teddyboys dancing over a red wolsey - What a pair of Coonts.............Discovery should copy Go Compare with their "How to kill the Tennor " and start inviting viewers to decide how Brewer snuffs it - I recon the Zone could come up with a few good suggestions winkeye
BATTS91
Tue Sep 11, 2012 10:24 am
Fuel return ?Correct me if im wrong but Didnt he just pull the vacume off the fuel pressure regulator ? That show is full of bollox !
Grrrmachine
E30 Zone Wiki / Team Member
Tue Sep 11, 2012 11:00 am
BEFORE: 0.65%
AFTER: 0.54%
Ed China: "And we've almost HALVED the carbon monoxide content!"
Having seen the E30 episode where Ed sprays a bonnet with a couple of rattle cans of primer before sending it off for a professional respray, I wouldn't trust that fop-haired monkey an inch.
G-Bear
Tue Sep 11, 2012 1:25 pm
Yep, monkeys does spring to mind when I see these two. Hadn't seen it in years. Then dug out the episode with an E30 on. Went on about huge power gains from an induction system and sourcing pattern parts. Makes me have my doubts...
HairyScreech
Tue Sep 11, 2012 11:44 pm
Diesel oil is a far better more gentle way to clean the engine out over many miles rather than dislodging everything all at once.
Have actually heard of engines leaking like sives and blocking always with grunge after treatments similar to this.
harry_p
Tue Sep 11, 2012 11:57 pm
Completely different though, this doesn't touch the oil / oilways. it's really just a high strength injector cleaner mixed with fuel which they plumb directly into the fuel rail.
I think for the money i'd rather have my injectors properly cleaned and serviced.
Without seeing independent before and after borescope pictures I'm massively skeptical about the stuff cleaning the combustion chamber, valves, lambda sensors etc.
cheers,
harry
HairyScreech
Wed Sep 12, 2012 2:10 am
Ohhhh its that one, my bad.
As you say still not worth it, send them to injection tune.
