Boot lock - Tailgate lock.....
Mo13
Post Mon Sep 10, 2012 4:45 pm
Had a quick search on the wiki couldn't find anything.
My question is what is the difference between the 2 locks and can 1 be fitted on to the other?
Grrrmachine
E30 Zone Wiki / Team Member
Post Mon Sep 10, 2012 4:51 pm
You put Locks into the Wiki and didn't get this?
http://www.e30zone.net/e30zonewiki/index.php/Locks
Sanchez
if you mean saloon and touring then there are different.
The actual barrel may be interchangeable but not the rest.
Grrrmachine
Post Mon Sep 10, 2012 4:52 pm
Sanchez wrote:if you mean saloon and touring then there are different.
This sums it up nicely:
http://www.e30zone.net/e30zonewiki/index.php/Locks#Boot
Mo13
Post Mon Sep 10, 2012 4:55 pm
Grrrmachine wrote:You put Locks into the Wiki and didn't get this?
I did get that but when I click on tailgate I get this:
Permission error
You do not have permission to do that, for the following reason:
The action you have requested is limited to users in the group user.
Grrrmachine
Post Mon Sep 10, 2012 5:03 pm
Tailgate's in red, meaning that page has not been written yet. But all the lock info is (conveniently) on the Locks page.
Mo13
Post Mon Sep 10, 2012 5:06 pm
Grrrmachine wrote:Tailgate's in red, meaning that page has not been written yet. But all the lock info is (conveniently) on the Locks page.
Thanks Grrrmachine
Boot
The rear end of each E30 is secured with a boot lock that locks the boot lid. Touring models also have a rear lock for the tailgate which is specific to that model.
While the boot lock is easily removed by unbolting it from the inside, like the ignition barrel, it is a sealed unit that cannot be dismantled and recoded. If your boot lock is broken, you will need to order a specially recoded one from BMW to match your other keys.
Is there any possibility at all of swapping the key/lock component from a touring into the casing of a saloon/cab to fit on to a saloon/cab?
or will I just F**K the locks up even trying?
Grrrmachine
Post Mon Sep 10, 2012 5:13 pm
I've tried dismantling a touring lock once to get to the tumblers, but there's so much specific plastic that makes part of the "sealed" unit that it's unlikely. I've never had a saloon boot lock in my hand to compare them.
Mo13
Post Mon Sep 10, 2012 5:26 pm
sounds like alot of hassle
I think it'll just be a lot easier to get a cab lock set
