Seized brake nipples
Farbbm
Post Fri Aug 31, 2012 3:18 pm
I dropped my car off to have an MOT and brake fluid change this morning, but i've just received a call from the garage to say that one of the brake nipples has broken off and at least two for the others have seized. The garage have advised changing the calipers but that sounds expensive. Any one have any advice or expierence of the this sort of problem?
macas
Post Fri Aug 31, 2012 3:20 pm
Yep...just get secondhand calipers...
bimanut
Post Fri Aug 31, 2012 3:22 pm
siezed nipples should come undone with a little heat.As for the one with a snapped nipple for the all the hassle of trying to get it out i`d just buy a second hand unit some one on here should be able to see you right :)
Motorhole
Post Fri Aug 31, 2012 3:43 pm
You can buy brake nipples on their own, provided you know the sizes - I don't know the E30 ones off hand but I'm sure someone here does. Havn't had a problem removing snapped nipples before, using the hammer & torx bit solution, but I guess there's always a first!
scjimbo
Post Fri Aug 31, 2012 5:24 pm
Motorhole wrote:You can buy brake nipples on their own, provided you know the sizes - I don't know the E30 ones off hand but I'm sure someone here does. Havn't had a problem removing snapped nipples before, using the hammer & torx bit solution, but I guess there's always a first!
flippin heck the poor old torx bits again. I bet you have shares in them winkeye
Topblag
Post Fri Aug 31, 2012 5:52 pm
It's always a good idea to check your nipples each time you have the wheels off. Never seen an E30 brake nipple which won't come out. Seen a load of fuds rounding them off.
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
Motorhole
Post Fri Aug 31, 2012 5:53 pm
My torx bits are 'ard mate :D
scjimbo
Post Fri Aug 31, 2012 5:54 pm
Topblag wrote:It's always a good idea to check your nipples each time you have the wheels off. Never seen an E30 brake nipple which won't come out. Seen a load of fuds rounding them off.
I check mine every time the misses is out winkeye :D
Post Fri Aug 31, 2012 6:06 pm
You can try using an Easy-out (reverse thread) extractor.
Post Fri Aug 31, 2012 7:11 pm
Theyre stupid money from BMW ( about £5 each IIRC 8O )
For the one thats bust off agreed get secondhand calipers
I had to replace the rears on the bronze turd for that very reason :cry:
Post Fri Aug 31, 2012 7:46 pm
If they are seized/tight the best way to do it is take the caliper off and get it in the vice for some gas axe action. Refitting the bleed nipples with grease will stop it happening again. Most mechanics dont have a clue and think excessive force is the only way to remove things, then when it breaks, swear and buy a new one
The thread is M7, cant remember the pitch but its standard, not fine
Farbbm
Post Sun Sep 02, 2012 6:08 pm
Care to expand on the hammer & torx solution? I've got an idea what your on about but thought I ask the obvious.
Motorhole
Post Sun Sep 02, 2012 7:28 pm
Brake nipples are soft, torx bits are 'ard...well, decent quality ones are. Find a bit that won't quite fit inside what's left of the brake nipple and tap it in with a hammer so its a tight fit, biting into the soft metal. Don't hit so hard as to damage the thread. Get a ratchet on the bit then wind out the remains of the nipple.
HairyScreech
Post Mon Sep 03, 2012 1:10 am
And often the act of tapping it in there will free off the thread as well, its a bit of a hack method however it works, and sometimes that's just what you need.
Farbbm
Post Mon Sep 03, 2012 12:16 pm
Excellent, I thought that was the method used.
