but what's this?
and an M50 manifold and e34 sump? surely not?
the E36 has a rear bowl on the sump, the E28 requires a front bowl.Sawyer_E30 wrote:gotcha. I thought the positioning on the sump was different on e28s and e30s? Or is e36 and e28 dramatically different?
i was going to remove most of the loom just in case i missed something i needed for the conversion before the shell goes for scrap.DanThe wrote:Why do you need to remove the fusebox? Let me know what ABS unit it has, I might come and buy the complete loom off you/have a nose etc
Could you not do the opposite to the m30-m20 gear box flange swap and put the larger pdc flange on the 260 box and use a 525i 528i prop?Andyboy wrote: You could also use the bigger, stronger M20 325i box (also found in the 12v E34 525i) and that means a shorter prop. Trouble is, the props you'll be using (E28 525i and 528i) normally have the big M30 prop donut that won't fit the 325i output flange. I had this issue converting a 525e from auto to manual and ended up getting a custom prop done - E28 rear half, altered E30 325i front half and balanced up. Using the 2 litre 240 box would be a lot easier.
.gcs325i wrote:Could you not do the opposite to the m30-m20 gear box flange swap and put the larger pdc flange on the 260 box and use a 525i 528i prop?Andyboy wrote: You could also use the bigger, stronger M20 325i box (also found in the 12v E34 525i) and that means a shorter prop. Trouble is, the props you'll be using (E28 525i and 528i) normally have the big M30 prop donut that won't fit the 325i output flange. I had this issue converting a 525e from auto to manual and ended up getting a custom prop done - E28 rear half, altered E30 325i front half and balanced up. Using the 2 litre 240 box would be a lot easier.
can someone just confirm that this is the way to go before i ruin a perfectly good sump?To fit the E34 sump to an M52 engine, you will need to remove the internal baffle plate (see pic). The plate unbolts, but it is also necessary to drill or grind down the mounting columns so that the bottom of the dish is flat.
alan1272 wrote:
i tried the 318is gearbox on the engine and predictibly it fouled on the clutch, so an M20 flywheel is required if someone out there has one.
hmm, can't see it needing a baffle like in that link, it's only a m52b28. it's never going to see a track or any nonsense like that so it'll be fine.Das_BMW_E30 wrote:I don't want to chuck a spanner in the works, but....
The sump might need a baffle installed / welded inside, to stop the oil going towards the back of the engine under hard acceleration, and starving the front mounted oil pick up of oil....
http://www.e30zone.net/modules.php?name ... c&start=25
It should be okay, but the winding tray is there for a reason.....alan1272 wrote:hmm, can't see it needing a baffle like in that link, it's only a m52b28. it's never going to see a track or any nonsense like that so it'll be fine.Das_BMW_E30 wrote:I don't want to chuck a spanner in the works, but....
