5 x 120 conversion?
Mike-
Post Fri Aug 24, 2012 9:07 pm
Thought the title might get some attention for people telling me to use the search bar!
HOWEVER, I know the work involved with this and frankly it's far too much to justify.
I really want to keep my E30 stock-looking, but the BBS wheels from E30s are a bit weak, I'd like something with a bit of dish, which has me looking at E34 items, which of course are 5x120.
eBay Wheels
See above for an example.
I've heard of wheels in the past having the bolt holes welded and then redrilled in the correct PCD. Is this something anyone has done before? As there's centrecaps it'll cover up any of the mess - or is this quite dangerous, along with steel banding etc.
Or are there any 4x100 wheels I've missed that are similar to these? Gotta be OEM
Opinions welcome.
Mike.
Cook318IS
Post Fri Aug 24, 2012 9:23 pm
What if the wheels look pretty OEM but aren't?
shanehaward
Post Fri Aug 24, 2012 9:51 pm
hub adaptors?
Mike-
Post Fri Aug 24, 2012 10:46 pm
I thought adaptors but E34 offsets will already be pretty low without having them spaced out another 25mm. I want to keep chunky tyres to keep it OEM so running stretch isn't an option.
fearlessphil
Post Sat Aug 25, 2012 4:06 am
im not actually that fussed about 'oem' in fact i hate alot of VW OEM enthusiast' (ok even though modern parts are 1000 times better than origonal in every way i must keep it origonal because im a comlete ****!!!) but i do like wheels that look like they could be OEM but most are 5x120 i wouli love to know if welding is an option or if a 5 stud convertion is viable?
jmc330i
Post Sat Aug 25, 2012 6:40 am
Filling and redrilling is possible, I know of 1 person on here (cant remember the name) who has had it done. Whilst he has had no problems, there will always be questions regarding welding ally on something as important as a wheel.
James
'91 325i Sport
'93 318i touring 16v
Jozi
Post Sat Aug 25, 2012 4:37 pm
You can get 18mm thick adapter from a US crowd, they look like a good job and not as thick as some others. You could look for 4x100 RS' or RM's and widen them?!
Mike-
Post Sat Aug 25, 2012 4:45 pm
I've had splits in the past and can't really be bothered with them! 18mm might be OK, I'd feel safer with those than redrilling.
Jozi
Post Sat Aug 25, 2012 5:42 pm
Not sure if this works:
These guys have them: http://www.8380labs.com/products/42-dra ... s-adapters
fearlessphil
Post Sat Aug 25, 2012 6:50 pm
they seem good except the price! $200 a pair i suppose thats not to bad though
Motorhole
Post Sat Aug 25, 2012 10:37 pm
e30.de do hub adapters too iirc, but for the price you're as well doing the complete 5-stud swap. I'm sure the weld filling is perfectly feasible but would expect it to set you back £50-£100 per wheel.
shanehaward
Post Sat Aug 25, 2012 10:46 pm
would vw hub adaptors fit ok? ive seen loads of golf etc running e30 wheels...
Phill172
Post Sat Aug 25, 2012 11:41 pm
Go with adaptors, if your dead set on 5 x 120, honest opinion it's alot of effort for some pretty boring wheels, there are lots of oem looking wheels in a 4 x 100
jmc330i
Post Sat Aug 25, 2012 11:49 pm
shanehaward wrote:would vw hub adaptors fit ok? ive seen loads of golf etc running e30 wheels...
VW are 4x100, so the E30 wheels fit anyway (other than offset being slightly out). I think the 5 stud VW is 5X112, so the adaptors are better as there is no overlap - 1 hole will overlap slightly when going 4x100 to 5x120.
James
'91 325i Sport
shanehaward
Post Sun Aug 26, 2012 12:06 am
i know, i ment would vw 4x100 work?
jmc330i
Post Sun Aug 26, 2012 12:15 am
I'm confused.... You want to use VW 4x100 adaptors to run E30 wheels which are 4x100??
James
'91 325i Sport
shanehaward
Post Sun Aug 26, 2012 8:28 am
no!!! lol
asking about the vw adaptors(4x100 to 5x120 or 5x130 etc ect..)because they are always on ebay second hand, just asking if you can use them because the centre bore is different :mad:
jmc330i
Post Sun Aug 26, 2012 9:14 am
Lol, it was late! :D
I've asked that before, but no answers. I guess it could be same as using the G60 discs on an E30 - you need to open the centre bore up a little, but I don't know if that would work or could be done on the adaptors.
James
'91 325i Sport
harry_p
Post Sun Aug 26, 2012 10:26 am
The vw centre bore is exactly the same as the e30 one. Vw adapters will work fine.
5x130 adapters are not that expensive as the 130mm pcd is wide enough that the holes don't clash.
4x100-5x100 are again easy as they just share a hole.
4x100 to 5x112 or 120 are tricky because no matter where you try and align the studs there will always be an overlap which means some sort of insert so the adaptor can bolt over the top of the stud.
cheers,
harry
jmc330i
Post Sun Aug 26, 2012 11:27 am
harry_p wrote:The vw centre bore is exactly the same as the e30 one. Vw adapters will work fine.
I cant find the particular WMS brake kit thread, but it says the centre bore of the VW discs used in their kits need enlarging to fit the E30 hub.
James
'91 325i Sport
harry_p
Post Sun Aug 26, 2012 11:45 am
Because the BMW hub is wider where the disk sits. The actual hub that the wheels sit on is exactly the same size.
People have been bolting BMW wheels on vws and vw wheels on bmws for decades.
cheers,
harry
jmc330i
Post Sun Aug 26, 2012 11:58 am
harry_p wrote:Because the BMW hub is wider where the disk sits. The actual hub that the wheels sit on is exactly the same size.
Ah, I think I get you - the hub tapers out at the disc mounting face, so the inner 1mm of the disc need removing?
And yes, wheels have been swapped between BM and VW for years, but people have also swapped wheels with the wrong centre bore for years (without using spigot rings etc) like BM wheels on Rovers, so just wanted to clear up any confusion.
James
'91 325i Sport
leeparkes
Post Sun Sep 02, 2012 11:06 pm
How about 4x100 BBS Mahle's? 15x7j ET13 so chunky rubber can still be used, they have a 2" dish and they were OEM, albeit they were on E21's but still OEM. :)
Ive had a couple of sets on E30's
Here's my current set that were found in a cellar in Germany. 8O
They now look like this..
Some old pics of my E30 with a staggered set on (7j & 6j)
http://www.e30zone.net/modules.php?name ... 29&start=0
Expect to pay about £250 for a rough set and around £500+ for a good set, a mint set sold for £800 on here last year but thats the most ive ever seen them go for, but the were in perfect condition.
My last set (the ones in the link) sold for £550 and the guy traveled all the way down from Scotland to the midlands to collect 8O
Cool old skool wheels FTW :cool:
