Last question first, yes get it done when car gets cleared, that way you'll get it for free and the best quality
The OEM finish is high gloss the 2k will achieve this, as for prep, give it a sand with some fine grit, 1200 will do, then give it a clean with white spirit, this will make the grain swell a little, sand again, give it a clean and its ready for the clear.
The reason for the second sand is the swolen grain of the wood will be removed, so when the clear hits it it won't swell further, giving a better finish.
The badge is only available as part of the knob. The knob is NLA
