my bmw
Any camera that has manual control can do the shots necessary for a tonemapped shot like the first one. You just have to make sure the camera is kept in EXACTLY the same position between exposures. The number of exposures needed depends on the dynamic range of the shot you wish to take but usually you can get away with three exposures (-2, 0, +2) if the contrast isn't too crazy and shooting raw will help also. If the shot has mad contrast then a larger range of exposures may be needed. And then as mentioned you need the help of software to blend the images together. Then you can tonemap the f*ck out of it if that's you bag, like the first shot.daymo69er wrote:u have to use a camera which can do hdr pics (takes 3 pics at different contrasts) then use photomatix to put the pics together and alot of playing around lol:) ,
