turbo help
verde
Post Sun Aug 05, 2012 10:58 pm
A friend of dads is stripping their diesell vauxhall frontera....im being offered a garrett blower for 50 quid. If I get the blower and intercooler buy one of those ebay turbo 6 branches it should work out ok?
Edit. Obviously not as simple as that but surely the 320 block will handle it and itl give a little boost
Raise hell praise Dale.
Motorhole
Post Sun Aug 05, 2012 11:12 pm
iirc turbo diesel turbos dont last long on petrols. Petrol turbos spin at higher rpm and exhaust gas is at higher temps. Also given the changes youd have to make to your management, injectors etc it probably wouldnt prove cost effective compared to an engine swap.
verde
Post Sun Aug 05, 2012 11:17 pm
Alright thanks motorhole. Il just wait til something else comes along. I might try get one off another car. I remember the mini ones are ok
verde
Post Sun Aug 05, 2012 11:29 pm
What needs done aswell
Turbo
Intercooler
Bov or antlag
Manifold
The injectors and ecu? What needs done and can u buy parts?
Barx325i
Post Sun Aug 05, 2012 11:39 pm
8O
leeparkes
Post Sun Aug 05, 2012 11:42 pm
Not sure how much boost you can get away with without having to go standalone, probably not a lot.
Then again if you dont really care if you blow the b20 up then i say go for it.
leeparkes
Post Sun Aug 05, 2012 11:51 pm
There were a few threads from years ago where a chip was used, not sure if there off the shelf though,
WAR chips is ringing a bell.
verde
Post Sun Aug 05, 2012 11:55 pm
Barx325i wrote:8O
One emote says a thousand words. When it comes to turbos I literally have noooo idea. Uum, I dont really wanna blow it up to be honest. Maybe a lumpy cam the 325 intake, 6 branch and one of speedtouches chips ( will be ordering soon dude ) will be fine for me atm. Maybe il port and balance everything if I get itchy again to do something. Probably best I stay away from snails
blackE30indy
Post Mon Aug 06, 2012 10:37 am
I think you can run up to 7psi on the stock ecu safely,think you need a
M30 afm,and injectors,
Some one has done it on the forum somewhere
Grrrmachine
E30 Zone Wiki / Team Member
Post Mon Aug 06, 2012 10:48 am
Even with 7psi, how much power are you going to get out of a boosted M20B20? About as much as a completely stock M20B25? But for more than it costs to do an M52B28? :mad:
ross_jsy
You are going to need to do a lot of research.
Have a good read through this:
http://www.e30tech.com/forum/showthread.php?t=3237
blackE30indy
Post Mon Aug 06, 2012 10:52 am
Grrrmachine wrote:Even with 7psi, how much power are you going to get out of a boosted M20B20? About as much as a completely stock M20B25? But for more than it costs to do an M52B28? :mad:
That's true :D
staley_turbo
Post Mon Aug 06, 2012 10:53 am
Unless your spending quite a lot to do it properly, it will be far easier and cheaper to go m52.
verde
Post Mon Aug 06, 2012 11:01 am
ross_jsy wrote:You are going to need to do a lot of research.
Excellent ross thanks. Il get stuck in. As I say for now il just balance the one I have and get it abit smoother and then see what happens next year. I just got curious as all I heard when dad spoke was garrett turbo 50 quid with intercooler and though hmm...i might get that. Il read that thread
