idle
gingerrusta
Post Sun Jul 01, 2012 9:11 pm
Hi
Today on my 320i 1988 Auto convertabile i changed the dizzy and dizzy cap as they both looked a bit worse for wear. The car has been idling all over the place. It seems to be a bit better when warm but does cut out alot when say you engaged reverse to move car.
Any of you gurus could give me some pointers on what to take off clean up and that kind of thing so i can get this beauty running like she should be please?
The dizzy and dizzy cap were bremi as i thought i didnt want any cheap shite on it.
Grrrmachine
E30 Zone Wiki / Team Member
Post Sun Jul 01, 2012 9:31 pm
lamby
Post Sun Jul 01, 2012 11:05 pm
check the ecu,i.e take it apart and clean it with wd40 and a toothbrush.if the roof leaked it will run down into it and cause this.same thing on mine and i done everything else first,pipes plugs valves fpr the lot!10 mins on the ecu and runs smooth no hesitation etc if you can,t see anything obvious like loose pipework then do this first,mine cut out when in reverse and at braking,even if the roof don,t leak now it will have done at some point!
gingerrusta
Post Tue Jul 03, 2012 11:56 pm
cheers i will give this ago as it will save alot of work. is it best to disconnect the battery when doing it first ?
Post Tue Jul 03, 2012 11:58 pm
Yes, disconnect it for an hour or so to reset it, reconnect then let it idle for at least 10 minutes to enable base idle settings to be learnt, switch off, then take it for a drive throughout the rev range.
Check the ECU code; if it's a later 380/381 ECU, these are notorious for blowing diodes in the idle control circuit.
gingerrusta
Post Thu Jul 05, 2012 7:35 pm
lamby wrote:check the ecu,i.e take it apart and clean it with wd40 and a toothbrush.if the roof leaked it will run down into it and cause this.same thing on mine and i done everything else first,pipes plugs valves fpr the lot!10 mins on the ecu and runs smooth no hesitation etc if you can,t see anything obvious like loose pipework then do this first,mine cut out when in reverse and at braking,even if the roof don,t leak now it will have done at some point!
i have taken Ecu out and sprayed WD40 on the pins and brushed them with a toothbrush. Do i need to actually open up the ECU or is this enough ?
Post Thu Jul 05, 2012 10:09 pm
It will probably suffice. The innards of ECUs rarely go wrong unless water gets in from a leaking windscreen seal.
Which ECU number is it, e.g., 0 261 200 172.?
gingerrusta
Post Thu Jul 05, 2012 10:35 pm
Speedtouch wrote:It will probably suffice. The innards of ECUs rarely go wrong unless water gets in from a leaking windscreen seal.
its a bosch 0 261 200 163
i plugged it back in tonight and run it for 10 or so mins on tick over and in fairness it seemed to run alot better. car is currently sorn off road so cant do the next bit like taking it for a nice drive to set it up properly.
but so far so good. its running a million times better at the moment :)
Post Thu Jul 05, 2012 11:31 pm
That will be a first-generation Motronic 1.3 with the twin-PCB (printed circuit board) design. If you can get hold of one, a later single PCB 172 ECU is more reliable, and easier to chip. :wink:
gingerrusta
Post Thu Jul 05, 2012 11:35 pm
is that the code it ends in 172 instead of 163?
Post Thu Jul 05, 2012 11:49 pm
Yes, 0 261 200 172 is the later 320i ECU.
Though, you can use any of the later six-pot ECUs (172/173/179/380/381) as they are all identical, apart from the EPROM chip - just change the chip to suit.
However, note that a 163 ECU chip will not work in a later ECU, and vice-versa.
gingerrusta
Post Thu Jul 05, 2012 11:55 pm
what benefits would i see if i changed it for one of 172 ?
Post Fri Jul 06, 2012 12:34 am
They're both Motronic 1.3, so no greatly noticeable gains apart from better reliability and the far easier availability of upgrade chips, which if you get a decent one winkeye will enhance driveability, performance and improve fuel economy.
lamby
Post Fri Jul 06, 2012 10:37 am
mine was the 163 which i changed for the 172 which made it run perfect,but after i stripped the 163 down,yes open it up you will have two pcb,s inside.cleaned it with wd40 and a toothbrush i put it back and it was sorted.HOWEVER i would strongly suggest you get a 172 before you clean the old one as they are cheap enough and if you bugger up the 163 it won,t matter,plus you can chip the 172 and yes it does make a nice difference on the auto.but def get a 172 and plug it in and see what happens
Grrrmachine
Post Fri Jul 06, 2012 10:57 am
Not only do I have a 172 ECU kicking around, I've also got one of Speedtouch's Mild chips to go with it...
gingerrusta
Post Fri Jul 06, 2012 6:31 pm
pm cost please
gingerrusta
Post Tue Jul 17, 2012 10:28 pm
update:
Rotor arm and dizzy replaced with brand new Bremi parts.
Ecu disconnected , cleaned with WD 40 with toothbrush
reconnected and ran car for 10 mins on tick over
Took car for run to mot centre and run through rev ranges
Failed on emissions running to rich
Got car home , disconnected ICV cleaned and reconnected
disconnected MAF cleaned and reconnected
disconnected the sensor under throttle body ( cant remember the name for this bit lol ) cleaned and reconnected
started car up and is running a little better but still doesnt sound 100%.
Any ideas???
Post Wed Jul 18, 2012 12:10 am
Check blue temperature sensor - should be around 3300 ohms cold, dropping to around 600 ohms hot.
Check air filter - replace if dirty.
Check exhaust CO emissions and adjust AFM if necessary.
Spray WD40 or similar around the inlet manifold gasket with the engine idling, and if it temporarily alters the idle speed then you have an air leak and need to either tighten the inlet manifold bolts or replace the gasket.
gingerrusta
Post Wed Jul 18, 2012 6:07 pm
how do i check the blue temp sensor? also whereabouts is it?
Air filter is clean
how do you adjust the air flow meter???
BenHar
Post Wed Jul 18, 2012 6:10 pm
gingerrusta wrote:how do i check the blue temp sensor? also whereabouts is it?
Air filter is clean
http://www.e30zone.net/e30zonewiki/inde ... oubleshoot
Ben
gingerrusta
Post Wed Jul 18, 2012 9:01 pm
Blue temp sensor does anyone know the part number for it please?
Grrrmachine
Post Thu Jul 19, 2012 5:37 am
Blue Temp Sensor info is here:
http://www.e30zone.net/e30zonewiki/index.php/Blue_Plug
You can use RealOEM to find the part number for things like this. The Blue Plug is part number 13621709966
gingerrusta
Post Mon Jul 23, 2012 7:23 am
update
Blue temp sensor has been changed. Seems to run alot better but this morning when i took the car to have its Mot it did one of the things it was doing before . Put it into reverse and it cut out.
What else could it be?
cecotto479
Caution Unreliable Seller
Post Mon Jul 23, 2012 8:24 am
Crankcase breathers blocked, split or disconnected accidentally? Dipstick not fully home?
1981 E23 735i
gingerrusta
Post Mon Jul 23, 2012 9:45 pm
cecotto479 wrote:Crankcase breathers blocked, split or disconnected accidentally? Dipstick not fully home?
where abouts are these?
gingerrusta
Post Wed Jul 25, 2012 8:46 pm
car is idling lovely now but emissions are at 9% . What next ?
Post Wed Jul 25, 2012 10:16 pm
What's the mileage? If quite high, it would be worth doing a compression test; all six cylinders should read roughly the same, at around 175-190 psi.
A Gunsons compression gauge can be bought cheaply from Halfords for around £25, and is a good investment, as you can use it to check any other engines you may need to. I've had one for years, and it's been reliable.
http://www.halfords.com/webapp/wcs/stor ... yId_255216
And what spark plugs are you using? The best for M20 engines are the NGK BPR6ES.
gingerrusta
Post Wed Jul 25, 2012 10:25 pm
car has done 107,000 so nothing major for this engine really. Im not sure what plugs it has in it although they were changed on the last mot a year ago. The car hasnt been used much .
Would the compression make it run rich ??
as you can see from the thread i have changed a few things and cleaned up where possible.
My mate at my local garage thinks it is the AFM as its not adjusting???
Post Wed Jul 25, 2012 10:27 pm
Well, if the car hasn't been used much, this may explain the rich running - big engines like this need regular excercise!
Check that the correct spark plugs are fitted and correctly gapped, and go from there.
gingerrusta
Post Wed Jul 25, 2012 10:37 pm
will try a new set of plugs . Are the ones you mentioned on euro car parts?
Post Wed Jul 25, 2012 10:43 pm
Yes, probably, or available from E-bay, etc.
Just a thought; my first E30, a 320i with L-Jet, failed the MOT one year because of excess emissions, and it had a stripped spark plug thread on one cylinder. When I disconnected the injector to that cylinder, it went down to a passable level!
So, carefully remove the spark plugs, and check that the threads are OK and that they seal properly when tightened up.
gingerrusta
Post Wed Jul 25, 2012 10:54 pm
ok cool will give that a try cheers. Thank you for your ideas and fingers crossed it helps :)
Will update when i have done it.
Post Wed Jul 25, 2012 11:01 pm
Examine each spark plug as you remove it, note the colour of the tip, and any differences between them.
gingerrusta
Post Wed Jul 25, 2012 11:08 pm
plugs or afm that is the question :)
lamby
Post Thu Jul 26, 2012 3:52 pm
wind the allen bolt on the afm all the way home counting each rotation,if its about 3 that should be ok as it does your mixture.mine was all the way out put it to 2.5 and emissions went just under 1,try it nothing to lose just remember how many turns
