M52 Donor Car
Motorhole
Going to check out a potential donor car (e36 328i SE) for engine, gearbox, prop etc tonight. 1997 car, fairly high mileage but cheap enough. Anything in particular I should be on the lookout for? Cheers!
alusil block.
not sure what year they stopped the other type nickasil or something or other
+ a yard full of scrap turds
Grrrmachine
- E30 Zone Wiki / Team Member
- **BANNED**
Depends on your objectives,really.
Once these plastic engines have over-heated,the block is goosed,but the crank,rods and pistons will fit an iron block M50
The head will skim up,but dump the M52 ECU and go with the earlier M50 item that can be mapped in the same way as an M20 ECU.
When my M50'd touring needs an engine re-build,that's my chosen route.
Youth is wasted on the young.
Barx325i
sounds like I should empty the trailer
Malcolm, I don't know why you have such a fondness for retaining the M50 ECU when sticking the 2.8 guts in a M50, the Siemens ECU on the M52 is a far superior bit of kit
- **BANNED**
It may well be,but you try getting some-one to re-map it!E30BeemerLad wrote:Malcolm, I don't know why you have such a fondness for retaining the M50 ECU when sticking the 2.8 guts in a M50, the Siemens ECU on the M52 is a far superior bit of kit
No need to though, they adjust very well to changes and you're just replicating a M52 anyway
Its not much different to remapping a Bosch M50 ECU, I think the point your raising is more to do with the fact an M52 ECU is not a simple chip swap job which most "tuners" favour. Remapping is a word used very looselydaimlerman wrote:It may well be,but you try getting some-one to re-map it!E30BeemerLad wrote:Malcolm, I don't know why you have such a fondness for retaining the M50 ECU when sticking the 2.8 guts in a M50, the Siemens ECU on the M52 is a far superior bit of kit
With the M52B28 ECU and your m50 iron block M52B28 engine there are no issues anyway, plug and play.
- **BANNED**
Not quite true young man!E30BeemerLad wrote:No need to though, they adjust very well to changes and you're just replicating a M52 anyway
M52 with M50 inlet,and a suitable ECU mod will make rather more than your stock M52....whichever block is used...
Motorhole
Thanks chaps! it looks good, no water in oil or vice versa, no fluid leaks, no rattle from the chain/tensioner or vanos, revs well and pulls well, changes gear just fine. Temp sat just under halfway throughout. Will take a day or 2 to consider.
Lee knows this, he has exactly what you typed above in his cardaimlerman wrote:Not quite true young man!E30BeemerLad wrote:No need to though, they adjust very well to changes and you're just replicating a M52 anyway
Andyboy
- Alpina Colada
Daimlerman typed that in Lee's car?
Blackberry innit
Morat
Where's the riot? I'm almost out of Basmati...DanThe wrote:Blackberry innit
