kw suspension
ameetgill1
Post Wed Jul 11, 2012 3:59 pm
what do you guys think of kw suspension?
MillRat
Post Wed Jul 11, 2012 5:40 pm
Love it.
Cheers,
Michael.
ameetgill1
Post Thu Jul 12, 2012 3:36 pm
I'm getting 35mil all around what u think
MillRat
Post Fri Jul 13, 2012 5:50 pm
ameetgill1 wrote:I'm getting 35mil all around what u think
35mm diameter struts? That sounds really thin to me (unless I am mistaken what you are talking about). I use 51mm V2 in my E30 race car and they have been great (rebound adjustable). Not a single problem in about 6 odd years. I have recently fitted slicks and have found the spring rate to be to soft now. On the road, or with semi slicks however, the spring rate was great.
I also had KW V1 in my A4 (not rebound adjustable). Once again they were great. My next car will also have KW coilovers.
Cheers,
Michael.
Grrrmachine
E30 Zone Wiki / Team Member
Post Fri Jul 13, 2012 5:52 pm
Think he's talking about the drop rather than the strut size.
MillRat
Post Fri Jul 13, 2012 7:56 pm
Grrrmachine wrote:Think he's talking about the drop rather than the strut size.
Okay that makes sense. So not their coilover series then, but their street series.
Cheers,
Michael.
ameetgill1
Post Fri Jul 13, 2012 10:20 pm
I'm talking about the drop. what do u recommend sports suspension or coil overs?
Post Fri Jul 13, 2012 10:26 pm
What model E30?
ameetgill1
Post Fri Jul 13, 2012 10:44 pm
yes e30
Post Fri Jul 13, 2012 10:59 pm
Which one?? :mad:
ameetgill1
Post Fri Jul 13, 2012 11:00 pm
ameetgill1
Post Fri Jul 13, 2012 11:15 pm
for my e30 cab
MillRat
Post Sat Jul 14, 2012 4:02 am
It all depends on what you want to do with it. I always entertain the thought of tracking my cars, even if it is only once; in which case I would personally lean towards coilovers. However if it is only for a daily driver which doesn't ever get more right boot than it takes to over take the car ahead of you then coilovers are a waste of money and you should stay with the lowered McPherson struts (they do exactly the same job, except you cannot change the ride height... I had my Audi for 5 years and in all that time, never adjusted the ride height once after setting them...).
As you have a Cab I think the normal struts should be fine.. and once fitted, you will probably never look back.
Cheers,
Michael.
Post Sat Jul 14, 2012 3:21 pm
YOu do realise that these coilovers will need to be welded onto your front struts, as with all coilovers for E30's???
