89 325i sport resto (work begins at last)
Fri May 11, 2012 4:55 pm
scott180gtb wrote:Now then dude.
We will have to catch up soon.
Ultimately I think I will go down the S50 route but a lot needs to happen before that.
As for having her back. No Chance :D
You can have me any time though :hump:
You can't S50 this thing!! 8O
scott180gtb
Fri May 11, 2012 5:14 pm
Andyboy wrote:
You dirty ******* whore. What's he got that I haven't? Eh? EH?!?
Wet Kisses winkeye
The Love I have for the M20 is unmeasurable. I'm alway's left wanting more bhp.
Its s50 or a s2000 kit car but again this is all time away.
Cars
2007 VW Caravelle 2.5 TDI 250 bhp 550 NM
1989 325i Sport Gone :(
2003 E46 320d Touring
1998 E36 M3 EVO Track Toy
1996 E36 328i Sport welder-up project
scott180gtb
Tue Jul 03, 2012 9:01 pm
Some pics of my recent arse end action!
Thats the back end all done. The car is back on all four wheels and spun round in the garage ready for some front end action.
I've got to figure out a way to support the donk whilst I remove the sump and subframe!
Plans for the future are to get the flywheel lightened and move some parts on to put some cash aside for a decent exhaust.
I also pulled the car out of the garage and gave her a little wash. I cant wait to get this finished
Cars
bab-91
Tue Jul 03, 2012 9:10 pm
shiny shiny :cool:
IG - bab91
redcar
Tue Jul 03, 2012 9:20 pm
Hi, may I ask, what underseal have you uses on this? It looks awesome!
scott180gtb
Tue Jul 03, 2012 9:55 pm
redcar wrote:Hi, may I ask, what underseal have you uses on this? It looks awesome!
I spoke to a few people to try and find the best way of going about painting the underside.
If you look back through the posts you can see there is a couple of stages.
I tried to mix paint with some anti gravel and applied it with a Schultz gun to get the texture/oem look.
This did not work very well as I could not get the colour right.
I ended up getting some solvent based paint mixed up in spray cans and just sprayed it all underneath. I can't stress enough if your going to do this get a good ventilated mask. I pushed the limits of stupidness painting in a sealed area without any ventilation. :o:
Cars
Kedge
Tue Jul 03, 2012 9:59 pm
Looking awesome!! Are you not going to Waxoyl it though?
Instagram - Kedge85
beardymat
Wed Jul 04, 2012 10:06 pm
If you mean underneath kedge then there`s no need as its now properly sealed and the waxoil will only help crap stick to it causing future problems. A bit in the box sections is never a bad thing mind.
I still want the beast back.
scott180gtb
Fri Jul 06, 2012 8:38 pm
Some more pics of this afternoons bodgery.
I took the sump off and this is what was left of the gasket. You can see it has blown out at the
gearbox end. I also removed some plastic o ring from the pump. I've cleaned up both surfaces ready for re-fitting.
Ive basically used a crane that Lee kindly lent me to take the weight of the engine so that I can get in a clean up both front chaise legs and repeat the same process as the rear.
Some major bodge work was required to remove the subframe whilst supporting the engine.
All ready for the new sump gasket and some serious TFR action. This was the bit on the front leg that I wanted to get too sort out hence the subframe coming off. Should all clean up nice though.
Cars
Kedge
Fri Jul 06, 2012 8:47 pm
I've just done the sump gasket on mine in a very similar way, hated the whole job. Most my gasket stayed stuck to the block and was a c*nt to get off.
beardymat wrote:If you mean underneath kedge then there`s no need as its now properly sealed and the waxoil will only help crap stick to it causing future problems. A bit in the box sections is never a bad thing mind.
Fairenough that, Dan has just kept drilling into me that I need to Waxoyl everywhere on mine.
Instagram - Kedge85
Fri Jul 06, 2012 9:18 pm
gonna be real purdey . :D
that arse end looks fantastic ....runs to the hills corked .
goosiegander
Zonegoose
Fri Jul 06, 2012 9:52 pm
Awesome work dude! :D
Kedge wrote:I've just done the sump gasket on mine in a very similar way, hated the whole job. Most my gasket stayed stuck to the block and was a c*nt to get off.
If you want it to stay rust free then you do, waxoil wont ever cause problems, and is the only long term rust prevention ive seen that works. If you keep the water out, there will be no rust, at the end of the day paint is only microns thick and nowhere near as good at keeping the damp out.
Sorry boys, but all those nice new brackets, covers and nuts/bolts will soon dry up and start rusting after a year or so of being on the road :(
Fri Jul 06, 2012 10:38 pm
copper slip or vaseline on all the pipe line fittings helps .
Alpina99
Sat Jul 07, 2012 6:49 am
magpie wrote:copper slip or vaseline on all the pipe line fittings helps .
Are we still talking about cars ??
:D :D
Gone, but not forgotten !!
scott180gtb
Mon Jul 09, 2012 8:21 pm
I'm unsure of what to protect it with. I don't think a bit of wax will do it any harm especially in the arch's etc. She will be having some paint in the new year and dare I say it it will only be used in the dry. :o:
I agree about the bolts as well Dan but it only cost £40 to have them all plated locally. Dry use should prolong the shiny :D
Cars
scott180gtb
Mon Jul 09, 2012 8:30 pm
I managed to get the gearbox off today. What a complete PIA job. I've took some pics of the bell housing just to show how badly this thing was leaking from the sump. It looks like the fly and clutch have had a good dose of oil as well. What do we think?
I've replaced the sump and cleaned up all around the donk. The good news is that it would only appear to be the sump that was leaking. No signs of oil from the head, oil filter housing, pressure switch etc.
Cars
Mon Jul 09, 2012 8:40 pm
Whilst it is off, it'd be a bit mad not to change the crank oilseal and gearbox input shaft seal mate
scott180gtb
Sun Dec 30, 2012 6:49 pm
I thought it was about time I updated this. Its been far to long since I did any work on the sport so I made a start again today with the hope of getting the car ready for the summer and possible moving her on to a new home :?
I had a bit of a mare when taking the BTB off as the last owner had the head gasket done and some of the head bolts had been replaced with bolts :o:
Anyway all 12 studs present and correct and a nice clean M20!
I've basically fully painted the car underneath now. It was much easier with the exhaust and front sub frame out the way and looks mental. I will get some good detailed pictures up soon but I was loosing the light when I finished today.
Many thanks to Dan and Steve for the front shock insert advice.
I was a little unsure the correct method to build them up but Steve put me right.
Lots of shiny powder coated bits and new bearings, rubber etc.
And finally a skinny flywheel thanks to Dan.
I'm ordering a new clutch tomorrow with some front disks ready for next weekend.
:D :D :D :D
Cars
Andyboy
Alpina Colada
Sun Dec 30, 2012 7:04 pm
ORSUM!!
What make dampers?
scott180gtb
Sun Dec 30, 2012 7:12 pm
They are RPM top mount adjustable Andy :o:
They might be a bit hard for road use but I'm going to give them a go. I like a good hard ride and there is always the option of putting some billies back in.
Dan advised me to put some OEM ones in but I bought these a while back and I'm going to try them.
I'm out in the sticks with a good selection of quality roads with good road surfaces.
I'm no city boy! :D
Cars
Craggy73
Sun Dec 30, 2012 8:56 pm
Fantastic rebuild!
Wish I had a garage to work in :(
scott180gtb
Wed Jan 16, 2013 6:38 pm
A quick update.
I've been a busy boy for the last three day's working in the cold garage.
Front arches all cleaned up and painted. Check those pads out, Proper!
I fitted the lightened fly along with the gearbox that had the seal replaced plus some fresh oil.
I then plumbed in the fuel lines, topped the donk up with some fresh oil and cranked her over a few times using the flywheel before jumping the m20 off :D
The prop is back on along with all the heat shields. Starting to come back together.
I just need either a log manifold or to stump up the cash for the rear section of the BTB3. I managed to pick up a club sport rack so its pipes from Dan and were about there. :D
Cars
Kedge
Wed Jan 16, 2013 6:57 pm
Nice arches 8)
Anything other than a BTB3 is a waste :wink:
Instagram - Kedge85
Wed Jan 16, 2013 7:52 pm
i've got a spare log manifold if you need one, i can get it refaced too.
Looking as good as the topside does!
The_Diddler
Love it up the more door !
Wed Jan 16, 2013 7:58 pm
very nice work Scott :D
Wed Jan 16, 2013 8:02 pm
Epic homofest! :D
Pipes are in Scott, ive had everything done in an OEM shade of yellow zinc just for you :D
Kedge
Wed Jan 16, 2013 8:07 pm
DanThe wrote: Pipes are in Scott, ive had everything done in an OEM shade of yellow zinc just for you :D
That's a homofest!! :wink:
Instagram - Kedge85
scott180gtb
Thu Jan 17, 2013 8:14 am
Thanks for the comments.
Simon thanks but I think I'm just going to plumb for the BTB3. I've got at least three more month's before she is road worthy which should give me enough time to get the brass together for the fannymold.
Dan I will need some spacers and UJ's as well. I will give you bell at the end of the month, ie pay day.
Paul, long time dude. How is the more door coming?
Cars
jimbom30cab
Tech 1 freak
Thu Jan 17, 2013 8:27 am
Scott, what did you paint those front inner wings with ?
ta
scott180gtb
Fri Jan 18, 2013 5:04 pm
Jim it's just solvent based lachs silver straight from an aerosol.
If you have a skeg back through the thread you can see I had various attempts at mixing paint with stone guard after seeing the results on the diddlers more door.
I spoke to Matt about mixing it up but couldn't get the colour right.
In the end I just used aerosols that I had mixed up in the correct colour.
The hardest part is getting the underside clean so that you are not painting over all the oil and road scum.
TFR and the gaffers scrubber brush gets it clean!
Enjoy
:D :D :D
Cars
The_Diddler
Fri Jan 18, 2013 5:37 pm
Slowly Scott very slowly :o:
spook
League two here we come !!!
Fri Jan 18, 2013 9:18 pm
so much epicness, what a car :cool:
beardymat
Sun Feb 03, 2013 9:45 am
Youre doing a grand job there Scotty, looks awesome. :cool:
The_Diddler
Sun Feb 03, 2013 10:38 am
beardymat wrote:Youre doing a grand job there Scotty, looks awesome. :cool:
Wow long time no see, how's things buddy........
