Where can I buy loweringkits 75-80mm?
Brinkland
Post Wed Jul 04, 2012 12:31 pm
Hello
on my previous e30, I had a FK Hightec sport suspension 75/50mm mounted ..... and now I bought another e30'er but different FK dealers say the set has been discontinued?
where can I buy a lowering kit that lowers 75-80mm in front? and 50-60 rear. - a complete set of shock absorbers
for do not think it's so good to buy a 60mm lowering kit, and then cut a ring or two in front?
It is a 6 cylinder with 45mm strut, sedan / limousine
hope you can help
Brinkland
1985 Bmw e30 325e
ross_jsy
Post Wed Jul 04, 2012 12:48 pm
Why does it have 45mm struts? You should have 51mm's with a 6 pot?
If you can get springs that low, which I haven't seen, it is going to handle like an absolute dog.
If you must have it dragging it's sump everywhere, you can get custom springs.
verde
Post Wed Jul 04, 2012 1:06 pm
Im guessing if you want to go that low handling wont be a priority? Coilovers or air ride is probably the most viable option. having the back that low is just daft, mine is lowered about 70 on the rear i think and im raising it as soon as i have the cash, it looks like the suspension has collapsed
Raise hell praise Dale.
Andyboy
Alpina Colada
Post Wed Jul 04, 2012 1:08 pm
It's all about optical tuning bruv.
Post Wed Jul 04, 2012 1:10 pm
Poundland is doing a special this week ! :)
ross_jsy
Post Wed Jul 04, 2012 1:11 pm
This will do it for you :D
Post Wed Jul 04, 2012 1:12 pm
I'm sure Pete can supply a set of 70mm "DIY Cut" lowering springs :D
aimlessrock
for all the ride comfort your going to get from such a drop you may as well use springs out of an old sofa!
E30 320i Convertible (1989)
190 Mercedes (1988)
verde
Post Wed Jul 04, 2012 1:18 pm
Do what the guy i saw on stance works did on his gorgerous 7 series.....he removed the front springs :| man that was a waste of a beautiful 740
Brinkland
Post Wed Jul 04, 2012 1:19 pm
ross_jsy wrote:Why does it have 45mm struts? You should have 51mm's with a 6 pot?
My old e30, had also 45mm strut ( 6 cylinder engine)
In fact, I had never scraped on anywhere
Brinkland
1985 Bmw e30 325e
Brinkland
Post Wed Jul 04, 2012 1:25 pm
how much do you think this one is lowered?
I want it as low ... just about
anyone know where I can get something that lowers so? I can not afford to air suspension
and what should I buy to get it to be so low there?
Brinkland
1985 Bmw e30 325e
Sjoerd320i
Post Wed Jul 04, 2012 1:32 pm
320's have 45mm front's exept the tourers and cabs.
You could also go for a 60 drop at the front and use drophats from an e90.
ross_jsy
Brinkland
Post Wed Jul 04, 2012 1:35 pm
Sjoerd320i wrote:320's have 45mm front's exept the tourers and cabs.
okay, whats is drophats?
ross_jsy wrote:Image
Hihi, maybe that is why the bmw on the picture is so low?
Brinkland
1985 Bmw e30 325e
verde
Post Wed Jul 04, 2012 1:37 pm
that looks like 60/60 maybe a bit more, 70mm perhaps. mine is 70 rear, 50 front? and its not much higher on the front than that one.
Kedge
Post Wed Jul 04, 2012 1:42 pm
AKA
Upper Spring Plate
While the lower spring plate is a fixed part of the strut the upper is a seperate part which holds the spring inplace and also acts as a housing for the top mount to sit in. Now this is a relatively uninteresting part, however it has recently come to light that this can be replaced by a spring plate from an E92 3-Series (part number 31336764093) which actually lowers the car by approximately 10mm by allowing the spring to sit higher in the wheel arch.
Instagram - Kedge85
Brinkland
Post Wed Jul 04, 2012 1:50 pm
AKA
Upper Spring Plate
Nice, thanks, they fit directly on? , You know what the price is? :)
Brinkland
1985 Bmw e30 325e
Kedge
Post Wed Jul 04, 2012 1:53 pm
Brinkland wrote:
Kedge wrote:
Brinkland wrote: okay, whats is drophats?
AKA
Upper Spring Plate
Yep, straight swap for the old ones. Can't remember the exact price but think they were £10-£15 each.
Instagram - Kedge85
Brinkland
Post Wed Jul 04, 2012 2:05 pm
Kedge wrote:
Brinkland wrote:
Kedge wrote: AKA
Thanks alot ! :)
Brinkland
1985 Bmw e30 325e
Morat
Post Wed Jul 04, 2012 2:14 pm
Buy a Golf?
Brinkland
Post Wed Jul 04, 2012 9:23 pm
Kedge wrote:
Brinkland wrote:
Kedge wrote: AKA
http://www.schmiedmann.dk/3er_serien/E3 ... 8.htm#1840
It is like them, these are just very expensive!! I just want to explore what those from an E92 will cost here in Denmark,
(it does not matter what year and engine size? - just say in a bmw dealer that it should be to E92?)
Brinkland
1985 Bmw e30 325e
Kedge
Post Wed Jul 04, 2012 9:38 pm
Just use the part number i posted. 8)
Instagram - Kedge85
rh306
Post Wed Jul 04, 2012 10:24 pm
Brinkland
Post Thu Jul 05, 2012 7:58 am
Kedge wrote:Just use the part number i posted. 8)
:rock:
http://static.bmwfans.info/images/epc/MTU1MTA1X3A=.png
Brinkland
1985 Bmw e30 325e
suchy
True Zone Relic
Post Thu Jul 05, 2012 8:28 am
Brinkland wrote: Image
Take a sh*t car and make it worse= tw*t
suchy
True Zone Relic
Post Thu Jul 05, 2012 8:29 am
rh306 wrote: Image
Take a nice car and make it sh*t= even bigger tw*t
He's even named this 'hella flush BMW'
:roll:
scjimbo
Post Thu Jul 05, 2012 9:19 am
Im surprised he hasn't stanced the JCB in the background :mad:
ross_jsy
Post Thu Jul 05, 2012 11:40 am
rh306 wrote::)
That's not a photoshop?
What the fook is wrong with people!
Sjoerd320i
Post Thu Jul 05, 2012 12:16 pm
That is a photoshop, the ckeckerd (?) pattern doesnt flow with the line's of the fender.
As is the same with the rear wheel.
The rest is real tho 8O
verde
Post Thu Jul 05, 2012 12:25 pm
Its cunts like that that have got tyre stretch noticed by the police
suchy
True Zone Relic
Post Thu Jul 05, 2012 1:36 pm
Sjoerd320i wrote:That is a photoshop, the ckeckerd (?) pattern doesnt flow with the line's of the fender.
Good shout. The bonnet looks 'shopped on also- just a piece of rusty metal, wrong shape with no centre bulge. The writting on the front tyre is mirrored also!! Didn't look at it closely earlier as it wouldn't surprise me if some dick actually did this :roll:
Brinkland
Post Tue Jul 17, 2012 11:03 am
I got the parts, shorter shock absorbers, springs 75/50mm from FK automotive, and so I bought a set of adjustable rear springs (30-80mm) and original upper spring plate from a BMW E92 as it is lowered further 10mm front
:D :D
Brinkland
1985 Bmw e30 325e
steve_k
Post Tue Jul 17, 2012 11:33 am
@brinkland, I've got those rear springs with adjusters myself & while they are very good just make sure you keep the adjustable platform's clean & greased because if you don't they WILL seize up & refuse to budge.
steve_k
Post Tue Jul 17, 2012 11:36 am
rh306 wrote::)
note to self, DO NOT TAKE LSD & THEN TRY & MODIFY YOUR CAR!!!!
why the fcuk do people think this shite looks good??
shadrack
Post Tue Jul 17, 2012 6:23 pm
m style do an 80mm spring kit
