z3 shifter?
verde
Post Wed Jul 04, 2012 10:19 am
I remember seeing a short shift kit thread and people talking about using the standard z3 one iirc instead. Would this be easier to do, does it shorten the throw much and will it stiffen my box a bit ( currently feels like stirring soup )[/quote][/u]
Raise hell praise Dale.
Kedge
Post Wed Jul 04, 2012 10:56 am
Instagram - Kedge85
Duke137
Post Wed Jul 04, 2012 11:11 am
Verde, sounds like you need to replace all the linkage bushes.
After 100K Plus and 20 plus years, they are worn out if original. It's the same theory for any rubber/moving/mechanical parts on the car, most E30's are tired turds now.
You want the Z3 1.9 shifter btw
verde
Post Wed Jul 04, 2012 11:20 am
Thanks lads. Those involved with the wiki deserve a knighthood. Will eurocar parts have all the linkages, mine are so bad I reckon a drift or a hard corner might make it hop outta gear
Duke137
Post Wed Jul 04, 2012 11:31 am
verde wrote:Thanks lads. Those involved with the wiki deserve a knighthood. Will eurocar parts have all the linkages, mine are so bad I reckon a drift or a hard corner might make it hop outta gear
BMW Only for the linkage parts, check realoem
Grrrmachine
E30 Zone Wiki / Team Member
Post Wed Jul 04, 2012 11:59 am
I just did all of this; shifter and all linkage bushes. It's gearbox specific, not engine specific. Total cost came to about 200 quid, and it's all BMW only.
Kedge
Post Wed Jul 04, 2012 12:02 pm
Grrrmachine wrote:I just did all of this; shifter and all linkage bushes. It's gearbox specific, not engine specific. Total cost came to about 200 quid, and it's all BMW only.
HOW MUCH!?!?! :eek:
You used to be able to get the Z3 lever and all bushes for about £35 a few years ago, i know BMW have since upped the level price a fair bit to cash in on the demand for it.
Instagram - Kedge85
verde
Post Wed Jul 04, 2012 12:10 pm
what the fuuuuck. i cant afford that shit.
**BANNED**
Post Wed Jul 04, 2012 12:19 pm
That's an eyebrow raising increase!
Last one I did was about two years back and the parts cost was well under £100,£60/£70 seems to ring bells.
The cost of the Z3 1.9 shift lever has risen,I expect that all us E30 types are to blame as the stock held at Munich will have run out and a fresh batch will have had to be made....
Well worth the cost and effort involved,be worth checking with Cotswold BMW for their 'best price' for the parts.
Grrrmachine
Post Wed Jul 04, 2012 12:32 pm
Sorry, got my exchange rates muddled (ordered from Lithuania, paid from Poland, converting to pounds...). My total cost was 125 quid. Still a hell of a lot more than the 35 quid of a few years back. Most of the cost comes down to three bits:
Actual Z3 shifter: 42 quid
Shift Arm Bearing (holds the shifter to the car body): 28 quid
Gearshift rod joint (holds the shifter to the gearbox): 35 quid
Then a dozen little clips, rings and pegs.
ross_jsy
Post Wed Jul 04, 2012 12:45 pm
£125? Ouch!
I'll be going for the AKG unit:
http://www.akgmotorsport.com/catalog/vi ... S230lg.jpg
8)
verde
Post Wed Jul 04, 2012 12:47 pm
Il see about taking this z3 kit off andyp and then il sorta out a drift style jdm dildoish knob and itl be sorted. be less like a bowl of soup and more like a gearbox
Kedge
Post Wed Jul 04, 2012 12:51 pm
Grrrmachine wrote:Actual Z3 shifter: 42 quid
I didn't change the bushes on the arms so that adds to the price difference.
ross_jsy wrote:£125? Ouch!
8)
All that's going to do is replace the BMW level, most of the bushes and linkage will no doubt be retained and so they'll still need replacing!
If you're ONLY changing the levers like for like the Z3 is probably still the cheapest but since the bushes are all 20+ years old you want to be replacing those while you're in there.
Instagram - Kedge85
Kedge
Post Wed Jul 04, 2012 12:52 pm
verde wrote:be less like a bowl of soup and more like a gearbox
You need to replace the bushes to sort this problem, a shorter lever is going to highlight worn bushes and make gear changes worse without changing them.
Instagram - Kedge85
verde
Post Wed Jul 04, 2012 1:01 pm
Definately but i think andy said all those parts were included...if not il buy new ones. Il make sure I do them all at the same time.
Grrrmachine
Also, the Wiki does need updating; there shouldn't be any need to bend the shifter rod since few cars should be running with the vibration damper on the prop these days. And RealOEM is rather confusing:
http://www.realoem.com/bmw/showparts.do ... g=25&fg=05
Part 13 has changed, so you DON'T need parts 18 or 19. Which will save you about one pound fifty :mad:
ross_jsy
Post Wed Jul 04, 2012 1:06 pm
Kedge wrote:All that's going to do is replace the BMW level, most of the bushes and linkage will no doubt be retained and so they'll still need replacing!
I don't plan on using bushes :wink:
verde
Post Wed Jul 04, 2012 1:08 pm
[quote="
Part 13 has changed, so you DON'T need parts 18 or 19. Which will save you about one pound fifty :mad:[/quote]
I think il buy me a house in the sun!
