recently bought wishbone bushes and drop links for ma e30, removed old ones (which was a nightmare) now i'm really struggling to get the wishbone bushes back on, the centre hole just seems so much smaller than the end of the wishbone and just wont bloody go on, its gettin on me tights,
checked the wiki but not really helping
any other ideas?
could i drill a small amount of the bush inside or sand down the end of wishbone? i know its meant to be tight but jesus it surely cant be this bad.
bloody wishbone bushes
e30mtech
i used copper slip and pushed them on,it's a struggle and on the second one i stopped for a breather half way through and watched it slide back up on it's own and pop off the end
+ a yard full of scrap turds
irish320i
washing up liquid is best no grease should be used as it causes the bush to wear prematurely by allowing it to move around inside the bush, washing up liquid just drys out.
Al
89 316i s50b30, 00 subaru imperza turbo(gone) 2005 range rover td6,
These will probably be still turning on the pins, and effectively scrap.magpie wrote:i used copper slip and pushed them on,it's a struggle and on the second one i stopped for a breather half way through and watched it slide back up on it's own and pop off the end
To the OP: Did you polish up the pin before you tried to push the bush on? They don't exactly slip on, but it should be easily achievable by hand.
spook
- League two here we come !!!
The strong arm of the Moore^
Sorry Brian.
Sorry Brian.
I used a scissor jack and the door frame from my garage to utility
i had a control arm off the other day and i did check the bush, its solid ie no movement.the fitting of these is that tight it pushed any copper slip out so i think i'll be fine .Brianmoooore wrote:These will probably be still turning on the pins, and effectively scrap.magpie wrote:i used copper slip and pushed them on,it's a struggle and on the second one i stopped for a breather half way through and watched it slide back up on it's own and pop off the end
edit...they've been in over a year now btw.
e30mtech
fairy was my next bet,
yeah i tidied up the pin
leeparkes
They are a bitch to slide on by hand, i was roaring like a wrestler on my last set.
mcbonio
Me and my brother with both of our strength together pushed em on, with a bit of fairy liquid.
