how many turns are your idle screw adjusted out?
I can only get my bmw to stand idle at 900 rpm, not lower? and my idle screw is adjusted only a turn out (that is screwed to the bottom and a turn out)
BMW E30 320i fra 87, (25/08/87)
No, not my air flow meter I talking aboutRtaylor2208 wrote:I take it you are talking about the Air Flow Meter. The only way to set this accuratly is via a gas analyser.
Which part is this,please?willnz wrote: Is the anti-stall unit set and working properly?
In Europe,we refer to this as an ICV,or idle control valve,no doubt in the land that refers to gloveboxes as cubbies,it has a completely different name!johnl320 wrote:
This bit circled, not sure if its called that over here, prevents the throttle snapping shut
Yes, det throttle stop screw is adjusted..willnz wrote:Is your throttle stop screw adjusted properly? Have you checked for air leaks into the intake? Is the anti-stall unit set and working properly?
I have standard filter on it, the picture was only to show the idle screwjohnl320 wrote:I would ditch that air filter first and put a standard one on.
Okay, thanks, the idling speed is different depending on which model it is?Speedtouch wrote:900 rpm idle speed is about right on an L-Jet 320i.
I have checked for air leaks, and it is not leakingwillnz wrote:Is your throttle stop screw adjusted properly? Have you checked for air leaks into the intake? Is the anti-stall unit set and working properly?
It hits only the arm when the engine is offwillnz wrote:Does it retract away from the throttle arm when the car is idling?
Yes the throttle stop screw is correct adjustedwillnz wrote:Ok, that is working.Brinkland wrote:It hits only the arm when the engine is offwillnz wrote:Does it retract away from the throttle arm when the car is idling?
Is you throttle stop screw adjusted properly? The butterfly should only just be clear of the body when set correctly (paper thickness gap).
