Fuel tank
B15NAC
Post Tue Jun 26, 2012 7:40 am
Hi
My fuel tank is leaking badly when filled with more than 10pounds worth of fuel! Would a gsf replacement tank be any good? Also any advice for fitting it? I've heard they can be a right pain to do!
Grrrmachine
E30 Zone Wiki / Team Member
Post Tue Jun 26, 2012 7:48 am
Have a read:
http://www.e30zone.net/e30zonewiki/inde ... _Fuel_Tank
I'm sure the GSF one will be fine; just make sure you get the right size.
B15NAC
Post Tue Jun 26, 2012 7:52 am
Yea I've seen that he makes it sound a easy job! But think it can be a pain if bolts start snapping off!
B15NAC
Post Tue Jun 26, 2012 8:55 am
True but that's why I'm getting a new tank an asking for advice on fitting!
Post Tue Jun 26, 2012 9:21 am
I've never had any trouble to date unscrewing fuel tank bolts. The rear ones are obstructed by the rear beam, so aren't quite as easy, but unless your car has spent half its life parked in the sea or a salt mine, they should unscrew OK.
Check out the steel brake pipes while the tank is out.
Andyboy
Alpina Colada
Post Tue Jun 26, 2012 9:28 am
As above, the 13mm bolts come out okay but use a 13mm spanner for the rear ones. The biggest pain can be the rubber intake hose which can really stick on and be a bastard to get off. I was taking a tank out of a scrapper a few days ago, got a bit medieval with the screwdriver trying to get the hose off - which went through the tank in a rusty bit around the hose....... :roll:
No idea what aftermarket tanks are like in terms of quality, but mint originals without rusty seams and rusty intake flanges are now rare.
B15NAC
Post Tue Jun 26, 2012 9:32 am
Ok thanks for the usefull advice! Will get stuck in at the weekend! Hopefully a gsf tank will be ok to use
Meatballs82
Post Tue Jun 26, 2012 1:56 pm
B15NAC wrote:Ok thanks for the usefull advice! Will get stuck in at the weekend! Hopefully a gsf tank will be ok to use
Hi,
If you haven't bought the tank already I'd be willing to bet I can save you money, pm me the details if you'd like a quote :D
