Basically has been driving fine lately, went to the shops tonight and was fine.. But then starting her up at a friends before going home she is idling rough (common problem).
One friend said it sounded like one of the pots was not firing and another stated the obvious plugs etc. Usually my father carrys out any engine work on my car as i am not the best, however he is away until friday, and i need to run the car
I plan on checking the plugs tomorrow and cleaning them, cleaning the AFM sensor and checking all of the intake rubbers etc. However if the problem persists will i be fine to drive it until friday 12 miles a day?..
When started it runs rough.. Rev the car to around 2-3k and she sounds okay but keeps popping a little bit when driving and backing of the pedal (more than usual)
Am i better off not driving it until then or should i be ok in the short term, as said the car drives fine but idles rough when parked and in low revs, but not enough for the car to die
