Removing cracked paint from M tech valance
Idol
Post Thu Jun 21, 2012 1:24 pm
Hows the best way to go about this? Mine has thick paint on it that has cracked.
Whats the best way of removing the paint before a re-paint? I dont really want to spend hours sanding.
Is there any chemical strippers out there that wouldn't harm the plastic?
Hot air gun?
HairyScreech
Post Thu Jun 21, 2012 4:12 pm
Had the same problem, on mine i found it was thick enough to get a razor blade and get under the edge, it could then be peeled like vinyl.
I was very reluctant to put another coat over the 5+ that were already in it and also did not want to risk chemical strippers.
I think anything strong enough to get the 2k off will also hurt the plastic and a heat gun will probably end up warping it.
mcbonio
Post Thu Jun 21, 2012 5:05 pm
I'm sure nitromours would be fine to use.!
Idol
Post Thu Jun 21, 2012 5:37 pm
HairyScreech wrote:Had the same problem, on mine i found it was thick enough to get a razor blade and get under the edge, it could then be peeled like vinyl.
Yeah mine has loads of coats on it. I'll give the razor blade idea ago cheers.
Idol
Post Thu Jun 21, 2012 5:38 pm
mcbonio wrote:I'm sure nitromours would be fine to use.!
Im pretty sure it will melt the plastic, but saying that, I have got an old cracked valance that i could test on ....
adit
Post Thu Jun 21, 2012 6:03 pm
a friend of mine was using nitromors to strip paint from her bathroom tiles and it starting falling off and into the bath. it was plastic and left marks like you get from bird droppings on paintwork
[quote="bss325i"]
pac1982
Post Thu Jun 21, 2012 6:05 pm
good old paint stripper, does exactly what is says on the tin, its not gonna melt through several mm of plastic bumper
1990 BMW E30 318IS (Sold)
1990 BMW E30 316i (RIP)
aimlessrock
Post Thu Jun 21, 2012 6:17 pm
nitromors is the one to use, but use it sparingly. I have used i for stripping part that have been painted (usually badly by former owners)
avoid getting it on your skin...it burns!
E30 320i Convertible (1989)
190 Mercedes (1988)
mcbonio
Post Thu Jun 21, 2012 6:30 pm
Get the Nitromors automotive stuff, works good on 2k paint..!
rich318i
Post Thu Jun 21, 2012 7:17 pm
problem is with stipper it sinks into plastic wont harm the ABS plastic but it will harm the paint once you paint it cos the stipper is still in the plastic
Gavla
Post Thu Jun 21, 2012 7:31 pm
Soda blasting? There are mobile soda blasters out there and it seems that it is the best way of stripping paint etc. Not cheap but it is effective, safe, and environmentally friendly.
maggspower
Turbo Farmer Tractor Driver
Post Thu Jun 21, 2012 9:47 pm
Gavla wrote:Soda blasting? There are mobile soda blasters out there and it seems that it is the best way of stripping paint etc. Not cheap but it is effective, safe, and environmentally friendly.
This, I have used my soda blaster to strip an mtech 1 spoiler with good effect.
Paint stripper is not the stuff to use on plastic parts.
polsta
Post Sat Jun 23, 2012 1:20 pm
surely a machine sander wont take long ? and also give a nice smooth finish with regard to re priming and painting, whos re painting it ? maybe just give it to them to do the full job
toby
Post Sat Jun 23, 2012 3:40 pm
Jet wash?
