cab door cards
lamby
the tops of my door cards dont fit well,like they have lifted,would i be able to bend them down or will this damage them,or are cab and non cab ones different just in case they have been changed?
- **BANNED**
This seems to be caused by warm weather distorting the backing card.
Remove from the car and use steam on the inside of the top of the card to soften it,then carefully re-shape.I added a self tapping screw at the jamb end to help hold the card in place.
Only happened to the driver's door card on my car,which really,rules out the warm weather theory!
It's not a permenent fix,BTW,mine really needs stripping and doing again.
Saloon cards are slightly different,as they have framed doors,they need a small modification to make them fit.
Youth is wasted on the young.
Z3I
When you steam the tops of the card, on the inside, before its set paint some glue on the card of a type that will soak into the card, to help it keep shape. Needs to be a water based glue. Gently clamp it to shape whilst it dries out.daimlerman wrote:This seems to be caused by warm weather distorting the backing card.
lamby
ok thanks i,ll give it a go,be like paper mache
