aerial wont go down stays up.. how to fix this plz
kangman
since buying my cabrio the aerial has been up, the previous owner said it was like that since the day they bought it and it hasn't bothered them.
but to me it looks like a radio controlled car when its parked with the roof off.
it has a after market headunit in there if that helps in anyway.
So how do i put it back down its an electric aerial
toby
First check the aerial itself. Pull back the trim in the boot and check if the command wires are connected to the aerial. If it's an original style aerial it has a red and white wire running from the aerial.
Take the headunit out and see if the aerial command wire is connected to the headunit correctly.
Better to pose these questions in 'technical help' .
kolee
Do you hear the motor trying to wind it in when you turn the ignition off?
If so take the Arial out an WA nk the shite out of it. I fixed mine like this, they seem to just rot and get stuck, although mine has since stopped working again. They are not hard to take apart.
toby
W an king it off may break all the teeth on the aerial track.
kolee
You take it apart first so its no attached inside the housing.
si911t
If its still knackered after you tried 'w n king' it (???) then some joy is that they not that expensive to get new one bought.
http://www.ebay.co.uk/itm/ELECTRIC-AERI ... 322wt_1185
kangman
my aerial dont need 'w*nking' yes it ups but thats not going to put it down.
the motor doesn't make any noise.
Is it hooked to the headunit or ignition?
ill check inside in boot when i have a minute and check the red n white wires are connected
toby
It should be connected to headunit...
cypriot_boy_2k7
It should be connected to the head unit, it should have an Arial signal usually blue, if not it might be connected to the remote output usually a blue and white wire, confirm this with a volt/continuity tester, post back your results
kangman
right i popped the bonnet and the cigarette and power aerial fuse had popped. i put a new fuse in but when i turned the ignition it was making a sparking like noise but it never popped.... HELP
toby
Take the fuse out and go and hide under your bed.
kangman
toby wrote:Take the fuse out and go and hide under your bed.
cypriot_boy_2k7
The motor is probably ceased, probably better to buy a new one
shnir
just stick a coat hanger in , i still get a good signal
sunnyr83
shnir wrote:just stick a coat hanger in , i still get a good signal
Barx325i
check the wiring going into the unit, it could be a dry connection. there should be a wiring diagram, so have an educated probe about with 12v and with a bit of luck it will go down. It could be related to the signal from the head unit & the relay
kangman
the popped fuse? and the clicking noise and it wont start when replaced with a new fuse.Barx325i wrote:check the wiring going into the unit, it could be a dry connection. there should be a wiring diagram, so have an educated probe about with 12v and with a bit of luck it will go down. It could be related to the signal from the head unit & the relay
Barx325i
if the fuse has gone then 'probe' the motor unit contacts/wires directly with 12v, and it may go down..
