ZF4HP22 auto
mark_i
Post Sun Jun 03, 2012 12:02 pm
i use the auto 325i for smoking around in and to be honest is pretty good for Sydney city traffic.
Last week, the tranny gives a moderate thump going from 3->4 and the lock-up clutch in 4th stopped working.
Today i drained the ATF, dropped the pan and strainer, cleaned it all carefully with lint free cloths and refilled with 4 litres of Dextron III.
still getting the thump shifting to 4 and still no lock-up.
Any thoughts...or a slushie from the wreckers?
Topblag
Post Sun Jun 03, 2012 12:21 pm
wreckers.
You'll pick up a 325 auto box over here for £50 - how much are they in Oz ?
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
mark_i
Post Sun Jun 03, 2012 12:33 pm
not sure... $100... pounds 60
the condition of the torque converter is a factor to consder
Andyboy
Alpina Colada
Post Sun Jun 03, 2012 1:06 pm
The lock up clutch has failed. I wou;dn't fret, just keep driving it as it is. If it's a non switchable type with a kickdown cable, try disconnecting or slackening it. An overtight cable can cause this sort of thing.
mark_i
Post Mon Jun 04, 2012 11:15 am
thanks mr Everett... its a non EH, so i'll check the kickdown cable.
out of interest, what causes the tranny to thump into 4th
Post Mon Jun 04, 2012 1:24 pm
isn't that the torque converter locking up?
mark_i
Post Mon Jun 04, 2012 1:43 pm
no Si, when the TC was working and locks, the revs drop another 300rpm at 50 mph when in 4th.
what i got is a definite clunk shifting from 3 to 4.
i was hoping that after backwashing the strainer and cleaning the furry magnets would have had an effect.
mark_i
Post Tue Jun 05, 2012 9:51 am
disconnected kickdown cable and... no luck.
Pity. even as an auto it pulls like a train with a mild speedtouch chip
mark_i
Post Wed Jun 06, 2012 9:43 am
hmmmm... after 250 miles since replacing the ATF, lock up clutch is working again
TPS
Post Wed Jun 06, 2012 10:03 am
I've got a 325i with a Switchable auto, it changes gear at 53mph, I think that means the torque Converter is working.
Post Wed Jun 06, 2012 1:23 pm
mark_i wrote:hmmmm... after 250 miles since replacing the ATF, lock up clutch is working again
Still getting thge thumping from 3rd to 4th? That's the worrying bit.
mark_i
Post Thu Jun 07, 2012 12:13 pm
yes, still getting the thud from 3rd to 4th... valve or clutch i wonder?
its irritating since otherwise the car is perfect as my daily after i front ended the red iS.
ah well, i got a switchable slushbox and loom i can use when i get a weekend free to do the swap.
