different coils
george101
Post Fri Jun 01, 2012 9:35 am
will a 316 coil from an m40 work with a 325 m20 engine? as i need one from my engine change, if someone could help me out that would be great.
thanks.
jmc330i
Post Fri Jun 01, 2012 10:24 am
You can look on realoem and check the part numbers are the same. I think they are the same, and Im sure I left the M40 coil in place when I fitted the M20 engine to my last touring, although it was a few years ago now so might have it wrong.
James
'91 325i Sport
'93 318i touring 16v
Grrrmachine
E30 Zone Wiki / Team Member
Post Fri Jun 01, 2012 11:05 am
Simple answer is no. Incorrect strut size and incorrect strength rating, all depending on the year and body style of both vehicles.
Jos
Post Fri Jun 01, 2012 11:08 am
I think he means coil as in HT coil, not springs Grrr :)
'94 e36 tree climber
Post Fri Jun 01, 2012 11:19 am
I have a genuine BMW/Bosch 325i coil available if you need one.
Grrrmachine
Post Fri Jun 01, 2012 11:21 am
:mad: Getting mixed up with my terminology now.
george101
Post Fri Jun 01, 2012 11:36 am
Sorry guys I meant the HT coil
Post Fri Jun 01, 2012 11:39 am
Just checked RealOEM, and both 316i and 325i coils are the same part number.
george101
Post Fri Jun 01, 2012 11:43 am
Speedtouch wrote:Just checked RealOEM, and both 316i and 325i coils are the same part number.
Brilliant thanks.
george101
Post Fri Jun 01, 2012 11:45 am
One last thing don't suppose any of you lot have a 325i dizzy cam and rotor arm? The rounded shape one
jmc330i
Post Fri Jun 01, 2012 12:24 pm
Grrrmachine wrote:Simple answer is no. Incorrect strut size and incorrect strength rating, all depending on the year and body style of both vehicles.
I was going with ignition coil. Although, as a side note, I ran my 318i touring with an M20 for a couple years on the standard 45mm struts with no problems.
James
'91 325i Sport
Post Fri Jun 01, 2012 1:52 pm
Standard struts in any touring are 51mm, unless it's a diesel, or, IIRC, one of a very few early ones.
jmc330i
Post Fri Jun 01, 2012 1:58 pm
It was one of the first '89 318i tourings, confirmed by VIN to have 45mm struts.
James
'91 325i Sport
Jos
Post Fri Jun 01, 2012 3:57 pm
Mine was 45mm struts too, much to my disappointment when my H&R kit arrived :( 51mm ones now from a 'pina, complete with springs
