constant buzzing from fuel pump?
cjdonny
Post Tue May 29, 2012 11:39 pm
only had car just over a week but im thinking theres a problem with the pump,there seems to be a buzzing sound (loud)
from the tank area
how easy are they to replace if needed and common problems
thanks
Post Tue May 29, 2012 11:59 pm
Age and model of car?
cjdonny
Post Wed May 30, 2012 12:01 am
:mad: sorry
H reg 1.8 m42 IS
Post Wed May 30, 2012 12:21 am
Fuel pump is easily accessed by pulling up the rear seat cushion and unscrewing the inspection cover on the right hand side. Pull off both electrical plugs, unscrew and remove four small nuts an washers, lift out the fuel level sensor, remove both fuel pipes, rotate the pump assembly anticlockwise and lift out.
Pumps become noisy when the copper commutator in the motor wears through, but this doesn't normally happen until the car has covered 200,000 miles +.
Another possible reason for a pump to make an excessive noise is if the underside of the fuel tank is dented in, and the pump is touching the bottom.
cjdonny
Post Wed May 30, 2012 12:23 am
cheers will look into it car has 125 on clock
318 IS
