The antenna and wires are all connected up at the boot end and I have the standard power antenna loom consisting of a red & a white wire running to the accessory socket behind the glovebox.
All I need to know is which sockets to the corresponding white and red wires connect into on the accessory socket?
Now for the drama.
The Pioneer headunit just works off a permanent live and earth from what I can make out.
Connected the earth, then connected the single orange wire from the headunit to the red/green permanent live. There was a short "crack" noise as the wires touched, which did not sound good.
The headunit won't come on and using my multimeter (although I have no idea what I'm doing with that) I seem to have no permanent live anymore.
I've checked fuse 12 and it is intact. The dashboard lights still work. The in-line fuse on the headunit (5A) still is intact.
Where should I be looking next?
I put my old Sony headunit back in quickly to see if it works (uses permanent & ignition live) and it fires into life.
Help as stupid spastic to get his new headunit to work please
Lee
