manifold heat shield
jimbob29
Post Fri May 18, 2012 4:10 pm
the left side of the shield has completely perished and was wondering if the heat from the manifold could melt or effect the ht leads in anyway?
ross_jsy
Post Fri May 18, 2012 4:17 pm
Can cause them to degrade. It's advisable to have them intact. Problems occur when removing the manifold with snapped studs etc
pukar
Post Sat May 19, 2012 12:24 am
have a look at this link....i had the same problem and did a fix which is still going strong after a few years...better than a snapped bolt!
Post Sat May 19, 2012 12:30 am
Never seen a lead that has deteriorated because of a missing heat shield. As long as the leads are located where they should be, there won't be a problem.
Later E30s with M40 engines don't have the heat shields, although the leads have hard plastic beads on them.
