MOT Fail :(
twoscoops
Post Mon Apr 30, 2012 12:27 pm
Yeah that sounds the same as mine. I have a new belt so I will hunt the wiki to try and work out how to change it. Cheers
labrat
Post Mon Apr 30, 2012 1:23 pm
If the belt replacement don't fix problem I would change the PS fluid.
I had similar problem but my belt was tight although not new it was in ok shape. The pump also used to make a nasty noise when under load.
I changed the fluid (which ent too difficult) and it was fine for 5 years until it was changed for a z3 rack.
1987 cab + M52B28 + 237bhp = smile machine
Rtaylor2208
Post Mon Apr 30, 2012 1:29 pm
Fluid was done just a matter of weeks ago as an attempt to solve the problem without going near the belt.
Post Mon Apr 30, 2012 1:36 pm
Rtaylor2208 wrote:Fluid was done just a matter of weeks ago as an attempt to solve the problem without going near the belt.
And what colour is the fluid now? Often takes multiple changes to get rid of all the old fluid.
If you don't but through ECP via Meatballs, then use this site, which is ECP without all the silly pretend sales and discounts: http://www.carparts4less.co.uk/
Rtaylor2208
Post Mon Apr 30, 2012 1:52 pm
Brian the colour was a pretty dirty redish brown. But after draining and refilling it twice its now the bright red colour it was when it came out the bottle.
Post Mon Apr 30, 2012 10:14 pm
Brianmoooore wrote:
Simon13 wrote:
Brianmoooore wrote: This procedure is detailed in your E30's driver's handbook (if you bothered to read it) as something you should do every three months
Nice attitude
If you have something constructive to add to this thread or any thread in any other forum outside of 'pub talk' or the 'kinderkar
The same applies to Dezzy.
We are losing too many relatively new members on here as a result of this type of 'banter', and there is likely to be a crackdown shortly, when we have finalised details.
what are you going to do Ban me? Your patronising remarks are not just lost on me........
"Crack on" wee man. Your about 6 miles wide of the pub talk and kindergarden remarks as they are hardly my hang outs on here. Whats the bloody beef any how because i'm Barrys friend? Is my resto thread not up to your standards? I'm lost.
Post Mon Apr 30, 2012 10:26 pm
If you break the rules on here, then yes, we will ban you, in accordance with out disciplinary procedures. This applies to you, Barry and every other member of the zone, including team members.
I've been following your resto thread, and find it fully up to the zone's standards - just the kind of thing we want on here, so I suggest you concentrate on that kind of post, rather than the sort of thing that resulted in you being jailed the last time.
BTW, the likely outcome of your cam saga is that you will be given a new cam if the original is wrongly machined as you say, but the consequential damage will not be covered, as you didn't carry out the necessary checks as this engine was built up. If you're lucky, you may get a contribution to you rebuild costs, paid without prejudice.
Dezzy
CR24v it's a lifestyle
Post Mon Apr 30, 2012 10:41 pm
Brianmoooore wrote:If you have something constructive to add to this thread or any thread in any other forum outside of 'pub talk' or the 'kinderkarten', then feel free to post - otherwise, don't.
I have just seen this.
I thought my post was quite funny (just me again then). It was completely tongue in cheek.
I had no intention of losing the zone any relatively new members. :(
Post Mon Apr 30, 2012 10:56 pm
Dezzy wrote:I had no intention of losing the zone any relatively new members. :(
Don't worry dez, I doubt your wit will have driven anyone away.
This seems to be a line that's being used quite a bit recently by the mods and a handful of zoners.
How accurate it is is anyones guess but you can bet its being blown out of proportion.
Dezzy
Post Mon Apr 30, 2012 10:59 pm
Loving the sneaky dig there Baz. Very nice work.
Post Mon Apr 30, 2012 11:07 pm
I didnt even get a 'drivers handbook' with my E30 :(
My brakes are still shit-hot though winkeye
macas
Post Tue May 01, 2012 9:29 am
I need to replace both my back plates on my 325,cos mine failed on the rear brakes being shite,are these a ball ache to replace?and are they still availiable from bmw?
Post Tue May 01, 2012 9:45 am
macas wrote:I need to replace both my back plates on my 325,cos mine failed on the rear brakes being shite,are these a ball ache to replace?and are they still availiable from bmw?
A complete "ball ache" to do 'properly', since the rear hubs and bearings have to be removed, often destroying the bearings in the process.
The usual bodge is to saw through the backplates in the area where there is a cut out for the callipers, twist and slide them on, then weld up the saw cut in situ. I'm in the middle of doing this on another BMW model at the moment.
If it's just the area that the brake shoe retaining pins twist into that is rusted out, then an effective and permanent repair can be made using the domed pin retaining washers from a drum brake set up.
**BANNED**
Post Tue May 01, 2012 2:51 pm
Brianmoooore wrote: If it's just the area that the brake shoe retaining pins twist into that is rusted out, then an effective and permanent repair can be made using the domed pin retaining washers from a drum brake set up.
These are available from Partco,called a 'fitting kit' and includes all the springs as well as the shoe fitting bits.£8.99.
Rtaylor2208
Post Wed May 09, 2012 5:46 pm
MOT Passed today and no advisories :D .
Most of the jobs turned out to be easier than expected. Although I did have to go down the route of glueing the split rear CV boot to get it through the MOT.
It'll be a trip to Boyds next month once I've got the extra cash to have it sorted properly.
On the plus side the new boge dampers, top mounts, bump stops , dust covers and power steering belt seem to be doing there job well, the steering is much more fluid and the damping much less crashy.
I better get saving to do the rears as well as they will most likely be past there best too.
Sanchez
Post Wed May 09, 2012 5:54 pm
boyds on sunday then?
Rtaylor2208
Post Wed May 09, 2012 6:31 pm
Nah, fishing in Northumberland
Topblag
Post Wed May 09, 2012 9:22 pm
Rtaylor2208 wrote:MOT Passed today and no advisories :D .
Nice one man. Good stuff. All you need now is some sunshine !
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
Andyboy
Alpina Colada
Post Thu May 17, 2012 5:39 pm
Even if a split CV boot isn't a fail, it should be. CV's don't last long with no grease, even less when rusty. Really, an MOT fail is doing you a favour.
