wires under inlet manifold
do-drift-1
I have a slight missfire, and not sure what it is now, i have tried all the conventional things, afm change, sparkplug change, oil change, ht lead change. . . The only things i can think of are left to do are injectors, fuel pressure regulator, blue temp sensor. . . And then i read about these green wires that are under the inlet manifolf. . .I can't seem to locate them at the moment, but if perchance someone would be kind to me and take a picture of where they're located, i'd be eternally greatful, cheers and regards as always. . . Richard
ALWAYS WANTED A BIMMAWAHH
Rtaylor2208
Which engine?
mcbonio
New distributor cap and rotor arm?
do-drift-1
Oh forgot to mention the engine, m20 325i, and yeah did the dizzy and rotor. . . So kinda doing a process of elimination here :S
Rtaylor2208
The wiring plugs into the underside of the Throttle body. You will really need to take off the large l shapped rubber intake pipe to get access to the connection.
