Simple question for anyone using a gearbox from an M40
Post Tue May 15, 2012 9:24 pm
Which prop have you used?
318i/316i or 320i?
StefanAnghel
Post Tue May 15, 2012 9:54 pm
Mine is 316i/318i if not wrong...have one prop in the garage if you want to try :cool:
e30-EVN
Post Tue May 15, 2012 9:55 pm
i used an m42 box barry which needs 325 front section
but iirc the m40 box is slightly shorter than the m42 so 320 front section is needed 8)
Post Tue May 15, 2012 10:02 pm
A 320i prop it is then.
I believe all the rear sections are the same.
e30-EVN
Post Tue May 15, 2012 10:07 pm
They are mate, but as you prob well know you're best off using a whole item as they are balanced and marked as such :)
Post Tue May 15, 2012 10:08 pm
Yep, that's what i'll be using.
