Which prop have you used?
318i/316i or 320i?
Simple question for anyone using a gearbox from an M40
StefanAnghel
Mine is 316i/318i if not wrong...have one prop in the garage if you want to try
e30-EVN
i used an m42 box barry which needs 325 front section
but iirc the m40 box is slightly shorter than the m42 so 320 front section is needed
A 320i prop it is then.
I believe all the rear sections are the same.
e30-EVN
They are mate, but as you prob well know you're best off using a whole item as they are balanced and marked as such
Yep, that's what i'll be using.
