M3 rear bench.
kitch
Will an M3 rear bench fit in a 4door? Or are the corner bits of the base different?
TIA
TIA
Steve
I have one fitted in mine no mods needed, it's looks bigger than the standard bench though.
I'll try and get some photos if you think it will help
webmaster@e30zone.net
Simon
As you've pointed out, the corners on the base are different, 4 door bases have a curved corner to make getting out easier, but a 2 door/M3 base will still fit fine.
don't listen to them,it wont fit and you should sell it to me
+ a yard full of scrap turds
suchy
- True Zone Relic
It will fit but you will need cabrio female belt clips as the normal E30 bench doesn't have the raised middle section and the inset clip holders are higher (if that makes sense!)
baur320
I know what you mean. I've an M3 rear seat in my 2 door and the buckles don't fit into the holders in the back section because the webbing is too short.
I checked realoem at the time and was sure that all centre buckles were the same so presumed an M3 shell had a diffent mounting point.
You sure about cab buckles?
Current E30 325i, E63 630is.
suchy
- True Zone Relic
They have the same rear seat shape don't they?
Don't know about a different mounting point though as I don't have an M3 to compare!
Anyone...????
Anyone...????
Simon
The mounting point on the M3 is different, I had in interior out of an M3 in a scrapyard years ago, on finding out the centre buckle in my 2 door didn't fit I went back for the buckle out of the M3 and found it was the same as the one already fitted.
suchy
- True Zone Relic
So does that mean cabs have the same mounting point as M3's then or do they have special buckles??Simon wrote:The mounting point on the M3 is different, I had in interior out of an M3 in a scrapyard years ago, on finding out the centre buckle in my 2 door didn't fit I went back for the buckle out of the M3 and found it was the same as the one already fitted.
baur320
What did you do in the end Simon? Don't fancy creasing the seat just to get the buckles in the holders.
Simon
IIRC, I managed to get them into the slots, but they didn't fit all the way upto the top, so never looked tidy.
- **BANNED**
On cabbies,the rear bulkhead has all the same mounting points as a saloon,but they are used differently.
The outer seatbelt mounts are used to retain the seat back,and the centre belt mount is used for the double female buckle,where the third,single,female buckle bolts in on a saloon.
Never played with an M3,so I have no information about the arrangement there!
Youth is wasted on the young.
- **BANNED**
For the purpose of improving my knowledge,Kieran,does the M3 backrest bolt in via two 10mm bolts,as in a 'normal' saloon?
kieran325
Yes it does, same fittings for both.
kitch
Thanks for all the info
. Looks like this could get expensive haha
Jozi
Does that meant the bas will also fit a touring? I'd love a m3 styled rear bench
It's no good anyway for 3 people, not that it's ever used
- **BANNED**
Best bet for a proper E30(touring)would be a custom re-trim of the existing seat frames,then use two single seatbelt fittings into the standard mount points.Jozi wrote:Does that meant the bas will also fit a touring? I'd love a m3 styled rear benchIt's no good anyway for 3 people, not that it's ever used
Remember that the saloons(lesser E30)use a structural rear bulkhead,this is replaced in touring with a stiffened floor and rear suspension upper mounts.
Jozi
I'm thinking if I ever get it retrimmed to get them to mould a M3 type bench and get rid of the middle. Might not fold forward anymore but feck that anyway - my touring will be far from a work horse when finished.daimlerman wrote:
suchy
- True Zone Relic
Ahh cheers didn't think of that- don't need the third belt anyway with an M3 benchdaimlerman wrote:On cabbies,the rear bulkhead has all the same mounting points as a saloon,but they are used differently.
