Engine fooked :(
Post Thu May 10, 2012 8:01 pm
Could the vacuum from the inlet collapse it?
eko
Old timer
Ill run the breather from the cam cover into a bottle and run it up the road to see how much oil is pushed out.
adit
Post Thu May 10, 2012 9:12 pm
eko wrote:
DanThe wrote:Next job = compression test
Yep,fooking thing can wait till it stops raining though,cant even be arsed to go out to it :mad:
that'll be next "Summer" then :roll:
sorry to hear this Tony, hope it's not as bad as you fear
[quote="bss325i"]
eko
Old timer
Post Thu May 10, 2012 9:55 pm
Right just finished having a look at it.
Disconnected the breather from the MAF pipe and ran it into a coke bottle.
Just took it on a 10 minute drive and checked the bottle,its empty with just a small trace of spatter inside it,also the smoke seems to have cleared.
It has to be my lashed up breather causing the problem.
For 18 months the 2 pieces of hose have just been secured with a cable tie.
When I sorted the split ICV hose recently I replaced the cable tie with the jubilee clip.
Heres a shamefull pic of my bodge....
So plan is ill do the job properly this time and just get the correct size hose and try it with that.
Will report back tomorrow when ive done it:?
Post Thu May 10, 2012 10:03 pm
things are sounding good .
Post Thu May 10, 2012 10:35 pm
Fingers crossed for you Tony!!
grantfk10
Post Thu May 10, 2012 11:24 pm
eko wrote:.
Hope it all works out ok for you.
The above is one of the major reasons I wouldn't consider buying a car with an engine swap tho. You never know, despite how good an E30 "enthusiast" is at transplanting engines, just what has been "bodged".
Even if that make-shift job has lasted for a while, it still isn't right.....
I'll wait to be flamed now :bolt:
eko
Old timer
Post Thu May 10, 2012 11:34 pm
lol
Probably not a good time to show you a pic of my engine mountings made out of lego then :roll:
78gizmo
Post Thu May 10, 2012 11:37 pm
eko wrote: For 18 months the 2 pieces of hose have just been secured with a cable tie.
Yet more proof cable ties are the best solution for fixing cars! :mad: Glad it looks like its sorted mate. BTW I have got the white touring on the road at last (now with M42).
Post Thu May 10, 2012 11:43 pm
Should have just kept quiet, and turned up at your house tomorrow with the trailer and a handful of folding stuff! I've just missed a cheap, tidy M52 touring. winkeye
grantfk10
78gizmo wrote:I have got the white touring on the road at last (now with M42).
That was my plan for my touring, but need to know it's done properly. How difficult was it?
eko
Old timer
Post Thu May 10, 2012 11:47 pm
Brianmoooore wrote:Should have just kept quiet, and turned up at your house tomorrow with the correct size hose,some new clips and a lecture on how to do the job properly to start with
See you at 4.30 then
eko
Old timer
Post Thu May 10, 2012 11:52 pm
How you doing mate?
Finally got the Touring up and running then.
They respond well to the M42,ive done a couple now.
You been in Gormans lately?
Keep meaning to pop in to see whats in but weather always shit and need waders in that place :mad:
78gizmo
Post Fri May 11, 2012 12:02 am
Sorry to thread hijack Tony!
Its a dead easy swap, just took me ages to finish off and Mot due to lack of spare time. Assuming you have an M40 in it now you just need an M42 with loom, ecu, full exhaust and coil pack. The M42 will go straight onto the original gearbox, you may need to change the spigot bearing. I also had to use my M40 engine mounting arms, but its all pretty much plug and play other than making a bracket for the coil pack.
78gizmo
Post Fri May 11, 2012 12:08 am
How you doing mate?
Am good thanks mate and pleased with the M42 conversion, it goes better than i expected. There were a couple of poverty spec 4pot tourings with just about everything trashed last time i went to gormans but the high tide has kept me away for a month or so!
grantfk10
Post Fri May 11, 2012 12:09 am
Thanx for that 78gizmo, might loook into that if the touring is a keeper :wink: And it's pretty solid anyway.
G-Bear
Post Fri May 11, 2012 10:38 am
lol
My Dad has used Lego on his cars in the past. He also cut a handle off a wheel barrow to weld to a tailpipe to get it through an MOT..
Hope the breather pipes the problem and that it's running good again soon..
eko
Old timer
Post Fri May 11, 2012 10:07 pm
Tragedy averted :D
Replaced the breather pipe and also put a new rocker cover gasket on.
Tin of carb cleaner through the TB and took it on a good run to clear the exhaust out.
All traces of Blue smoke have gone and back to running how it should be.
Thanks to those giving advice,im a happy chap again now :wink:
Post Fri May 11, 2012 10:23 pm
G-Bear wrote:My Dad has used Lego on his cars in the past. He also cut a handle off a wheel barrow to weld to a tailpipe to get it through an MOT..
I have also done the wheel barrow handle exhaust bodge - someone else's suggestion, when I happened to need an extra 4" or so spliced in. It was a perfect match, and survives to this day, some 2 years on! :)
Post Fri May 11, 2012 10:25 pm
What about the wheel barrow though?
Post Fri May 11, 2012 10:31 pm
Rest assured, it was a shagged turd of a barrow, thrown away for scrap.
andyp
True Old Skooler
Post Fri May 11, 2012 10:37 pm
tell her i said to stop the drifting on the way there and back lol
grantfk10
Post Fri May 11, 2012 10:43 pm
I have an old wheelbarrow that I was gonna take to the dump. Reckon I'll hang onto it for a bit longer now :wink:
adit
Post Sat May 12, 2012 12:12 am
good news Tony :clap:
[quote="bss325i"]
G-Bear
Post Sat May 12, 2012 8:09 am
DanThe wrote:What about the wheel barrow though?
Just happen to be at my parents at the moment. Popped into the garden. The one handled wheel barrow is still there some 15 years on, next to a shinier one with both handles on.. Must be saving it for another MOT..
Good news about the engine eko...
