My Mauritius Blue 1993 318i Convertible - NOW 325i + MOT
matt86
How long did it take you to do this and rough cost, me and my brother were going to do it together he's a mechanic.
tom325sport
Time it took to do the engine conversion? You could do the whole thing in a day - engine out and in! However if something needs changing (which it will - exhaust manifold bolts come to mind) factor this in.
Just take your time - It took me several long weekends (due to work) to do it properly and I still had little niggles getting it to run - Nice feeling when it all worked though.
Cost? Again depends what you want to do to it?
matt86
Just engine swap 318i out 325i in.
So I need all these bits?
Engine + Gearbox
Engine Loom (Read Brian Moore's write up first)
Diff
Rad
Prop
Exhaust
ECU
2.5 Coding Plug for Speedo
Engine + Gearbox
Diff
Rad
Prop
Exhaust
ECU
tom325sport
Yes - All these bit are out of your other 325i cab.
Other things you might need when finished - Bracket for the airbox and fuses. Also a bracket for the coolant bottle. I fabricated my own though.
Go for it - It is a plug and play job. Just read this first - http://www.e30zone.net/modules.php?name ... ring+brian
tom325sport
Oh and one last thing - Swop the front springs over as well. The 1.8 springs won't take the weight of the m20 engine. Or buy eibach pro kit suspension like me - they are fantastic!
tom325sport
Another Update - Weather was nice - for a while!!
Fitted these as well
And exhaust. Scorpion Back box and Middle section. - As I don't use it that often I can get used to the noise!
Also decided to try the 'smoked' effect on a spare set of lights I had. I used a baking tray! Not bad for a first attempt but will try again and get the cross-hairs spot on next time. I'm not sure about them at the moment but have a clear set that I can always put back.
I borrowed these old snips from a neighbour who worked on trains years ago! They did the job!
- E30 Zone Meets/Events Team
Looks like the crosshair in the driverside has lobsided
Looking at your pics, you didn't cut any locating tabs
tom325sport
Yeah first attempt I suppose. Will re-do them this weekend. Otherwise i'll be in touch to buy some off you Rav
There's a pm sitting in my outbox for you
Duke137
Standard lights in that FTW
